California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,938
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I read Ultrarunner's recent thread on plastic pipe but I can't draw any conclusions from all the diverse opinions I read.
My location is similar to his (North Bay in this case) and the application similar:
The galvanized pipe from pumphouse to barn is rusted through and leaking, and another line beyond the barn sprung leaks in three places so I capped that one temporarily. One of these lines was installed in 1978 and the other a few years previous. Other lines here are open-air and were originally fed from a windmill and overhead water tank, so these might a hundred years old. We've replaced rusted out sections of the open-air pipes at several points where they sprung leaks. Its time to replace everything.
The water tests with acidity greater than is allowed for a municipal system and it has so much iron that galvanized pipe is choked with rust when I open one up. In some cases, plugged up in less than ten years. The soil also makes rust on tools and implements etc much faster than it should.
What should I use to replace these water lines? I assume some type of plastic pipe. And maybe a different type of pipe for the above-ground portions, at the pumphouse and for the outdoor sink etc. Freezing here is occasional, mild, rare - the open-air windmill tank lines never were damaged.
Something like PEX that can tolerate a mild freeze (with the water turned off) might work - except for its sun exposure aspect.
Any advice?
Any advice?
