Putting my BX1870 to work splitting wood
/ Putting my BX1870 to work splitting wood #12
I suspect he may have an 1870-1, the new version, where the ROPS goes straight up without the flare-out. Kubota changed that, and added a fold-over that goes most of the way down. I suspect they took a lot of heat for the ROPS on the original 1870. I bought one of the last 1860s because I didn't want the 1870's ROPS. Very happy with the non-folding ROPS on the 1860, BTW.
How new is the new version? I just bought mine 2 months ago.
Hi Steve,
Would you post some closeup pics of your splitter setup? I am considering a similar project for a similar sized tractor (BX1860) and wanted to see how you handled a few things.
Thanks
wrooster
I'll try to take some tonight after work. The only gripe I have is that the top link is a tight fit, I should have made where the top link connects to the splitter a little higher up, the top link has to be all the way retracted and I have to do some finessing to hook it up. Shouldn't be to hard to fix, I just haven't gotten around to it. Other than that I am happy with it. The table comes off so it has a small footprint for storage. I have some heavy duty casters mounted to the draw bar and I use one of those snow mobile dollies (the ones that go under the track/skis) for under the jack foot plate and that allows me to maneuver it around without too much trouble.
FWIW, I have a very nice pto splitter that I used on my BX22. The cycle time as I recall, was 10 seconds or so. It was plenty fast enough for me as I don't think I wanted to work much faster anyway. I no longer burn wood and if someone here wants it 850.00 will take it away.
FWIW my pto pump alone was $560 so that seems like a more than fair price.
To answer the ROPS question, its the 1870-1. I had the dealer order one since the ROPS on the 1870 would make for a tight fit in my shed. If that didn't work I was just going to order the 1860 ROPS through whole goods.
As a side note, I had to add suitcase weights to the front with the splitter mounted to the back to offset the weight.
Hi Steve,
Thanks
wrooster
Here they are. Hope they help out with ideas.
Steve, great set up. A couple of questions if I may:
How did you get your ROPS to fold down that much? They don't go that far on my 1870
Second, Only if you feel like it LOL, could post a pic of how your steering lines on routed on the left side of the motor? You will have to slide off the engine cowl/surround. I'm curious to see if they run behind a GRAY bracket that supports a motor mount. Mine were and because of that, they ruptured at 20 hours. Just curious how other 1870's are routed.
I took a quick look with just the hood open but couldn't see anything. When I do my 50 hour service I'll try to remember to snap a few pics.
I think the only difference is the ROPS. I have a BX25 and wish they kept the brake pedal on the same side in the 70 series.
Ok, maybe it is the beer but didnt he have an 1870.... And now a bx25?????
Sorry, after I read it I see the confusion, I was trying to answer 2 questions at once. What I was trying to say was the difference between the 1870 and the 1870-1 was the ROPS. As far as how do I like it - overall I like the tractor, I also have a BX-25 and wish they kept the brake pedal on the same side for the 70 series. I rarely use the brake pedal on either tractor other than for engaging/releasing the parking brake but it would be nice if they were the same.
Deere 35P (A53317)
Deere 35P (A53317)
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
KJ K2512 25'x12' Metal Shed (A60463)
KJ K2512 25'x12'...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
