Setting top link on finish mower. Am I doing it right?
   / Setting top link on finish mower. Am I doing it right? #1
Bluest
Whitworth, Lancashire, UK
Yanmar F14D, DR Wheeled Trimmer
After months sorting out all the minor faults with my very cheap tractor and finish mower, I finally spent a day cutting grass. All seemed to go well, except I'm not sure about the 3ph top link.
To allow the mower to follow the contours of the ground I need to extend the top link so that the mower can hinge up and down in relation to the tractor. The problem with is that when I want to raise the mower for transport I then have to crank the top link short again, other wise the 3ph will only lift the front end of the deck. I hope you can unstandardised what I mean, it is very time consuming to jump off and adjust the link every time I want to raise the deck, or vice versa. I'll post some pics if my description doesn't make sense.
I think a hydraulic top link would be the answer, but I just wanted to check I'm not doing anything wrong before I look to spend more money.
   / Setting top link on finish mower. Am I doing it right? #2
You're doing it right...leave it long for mowing and shorten it for transport.
As far as "time consuming"...that's a relative statement. I get off to adjust the top link when I'm at the area I'm going to mow, then shorten it when I'm finished. Takes (maybe) a minute to do this, from off the seat to on the seat.
Tractors are great tools...so are finish mowers...but sometimes you have to get off your ***...
   / Setting top link on finish mower. Am I doing it right? #3
Yes, you need to leave some slack in the top link to allow the tail to follow contours... but perhaps you are getting a bit excessive? Find a happy medium where it can still lift the tail up when raised to transport but also droop enough to follow ground contours.
But a hyd top link would be nice...
Thanks Roy for confirming its laziness rather than lack of technique! It probably gets on my nerves as I'm not in a routine yet. So I mow a bit, raise the deck to cross some rough ground, mow a bit more, raise the deck to go back to the garage, then realise I forgot a bit... More forward planning required I think.
   / Setting top link on finish mower. Am I doing it right? #5
Since you're transporting across a short area, there's nothing wrong with leaving the rear wheels (of the mower) on the ground. I do this quite frequently for short distances...with a finish mower as well as a field mower (rotary cutter).
My apologies for the "get off your ***" comment....that was uncalled for.
I just set the link so that the tail has equal range up or down from horizontal. I do have a lot of hill so I use the full travel and some on most passes.
As for hyd. top link. I have the spare couplings on the tractor already, so f I see a used one I'll go for it. Would be useful to make my transport box a tipping one too.
No need to apologise, it made me laugh. All taken in good humour. Plus you were right!
   / Setting top link on finish mower. Am I doing it right? #8
perhaps you could try an old trick that works. Instead of using a rigid top link, use a chain instead. it will allow the mower to float and follow contours of land, but when you want to lift the mower, the chain will let you.
   / Setting top link on finish mower. Am I doing it right? #9
I don't know what kind of finish mower you have but here's what i have done to my mowers. I have King kutters and mow large parcels of land which is all hilly and a bit rough. I didn't like the rear frame work the mowers had so i removed it and put 5/16" chain from each of the rear corners to the top link. My mowers follow the ground much better, raise more evenly and ride much better in transport. I dont Mess with the top link hardly at all. I have a Hydralic Top Link on my Kioti but not on the Mahindra. The Mahindra is the primary mowing tractor. I set the top link and very seldom touch it again.
My mower has a "flex hitch" on it and with the rear chain lift and "flex hitch" it never scallops the ground.
Personally, i will never buy a mower without the "Flex Hitch" system.
BTW there is 8000 acres of mowing on that mower now . . . John
My mower is a small 4' version of the one picture. Maker and age unknown.
If I used chain, either as in pictures, or to replace the top link, I think I would still need to adjust the tension to get the droop I want and still be able to pick the mower up.
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
1284 (A58374)
1284 (A58374)
2021 BOBCAT T870 SKID STEER (A52709)
2021 BOBCAT T870...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
White Metal Roof Panels (A55758)
White Metal Roof...
