Trouble starting the Ford 8N. Pushing oil back through the air filter
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #1
macecase
Princeton, KS
1965 John Deere 3020 Diesel and 1975 John Deere 4630 Diesel
See video....
I am having trouble starting the Ford 8N. It has been very reliable and then stopped working....
While trying to start it, the starter made a weird noise and as it started to turn over, it blew oil out of the oil-bath air intake. It actually popped the oil reservoir off of the air cleaner and spewed oil through the vents in the hood.
Any thoughts? The starter sound isn't normal and it is puttering while trying to start. The oil thing has me baffled.
I did get it started earlier than this video. But, it was shaky. When I put it in gear, it died.
I have installed new spark plugs and also installed an ignition maintenance kit (points, rotor and new distributor cap). I replaced the coil and also the coil wire. There were two spark plug wires I replaced as well.
Best I can tell, I did the order of the plugs and cylinders correctly. The distributor goes counterclockwise, right?
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #2
It sounds like it is turnibg over backwards. Had this happen to a 8n myself.
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #3
Possibly, one of your intake valves is hanging open for some reason.
What would cause it to turn over backwards? How did you remedy this when it happened to you?
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #5
that's exactly what I would think it would be.
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #6
i'd really like to see that on a stock 8n starter and drive gear...
If this is the case, how would I fix that? Would I need to take the valve plates off and try to get it "un-stuck" or would it be more involved? I am guessing take the head off?
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #8
i'd take the valve covers off firest and strat with some solvent / penetrating oil and scrub the exposed stems and try to get solvent sprayed down. carb cleaner.. acetone and atf mix.. etc. spring pressure should close them and cam lifts them.. many times if you can get htem moving a hair.. and keep the loosen juice poured to them they will move more and more on each stroke till they free up.. then you keep cleaning them.. then you change the oil. :)
Personally.. any time i have an engine with stuck valves.. once it get the valve train repaired I change the oil with walmart or other store brand cheap full synthetic oil, then run that thru to help finish getting some crud out... Many times you find it is the intakes that stuck.. and of the ones I've worked on.. it's my opinion that it is deposits left from the crap they pass off on us as gasoline these days. it doesn't burn off the intakes, and they stick. I've had valves i had to drive out of heads with a hammer before they were so stuck.
   / Trouble starting the Ford 8N. Pushing oil back through the air filter #9
ps.. once you get the side covers off.. you will know if it is a stuck valve or not..
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2012 Golf-Lift Hydraulic Turf Equipment Lift (A49462)
2012 Golf-Lift...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2023 LandHonor RTR-12-72W 72in Root Rake Skid Steer Attachment (A49462)
2023 LandHonor...
19009 (A48082)
19009 (A48082)
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
