Cutting grass around pond
/ Cutting grass around pond #1
Thomabear
Cut Off, LA.
Massey Ferguson 1740M
I've spent quite some time searching for an efficient way to trim my pond bank and I haven't heard about anything that works really well with minimal effort. The levee end of my pond is about 250' long and has a non mowable bank about 3' wide on about a 45 degree angle. After reading about the use of hanging push mowers, DR mowers, sickle bar mowers and weed wackers I started thinking about adjustable angle pole hedge trimmers. Unfortunately no one has mentioned one of these so I'm not sure about how well one would work. In theory and given my pond bank angle I think this approach would work well. Advantages would be that the weeds would lay where cut and not fly into the pond. This should also reduce erosion as the thatch would provide protection from rain induced washing. Any ideas or suggestions? Do you guys think this would work? I'd prefer to not invest in a sickle bar mower for 250' foot of levee and I certainly would prefer a save approach verses hanging a rotating piece of equipment. See attached link...
Thanks for any and all advice...
/ Cutting grass around pond #2
I think you will break that unit real quick.
This is Power-Tracs answer to something like that. Is is hyd powered.
/ Cutting grass around pond #3
To get away from labor and maintenance once and for all have you considered planting low ground cover plants ? Using roundup to kill the existing weeds and grass and then planting low growing multiplying plants that grow in your area....then it is done....
/ Cutting grass around pond #4
You can't use Roundup that close to the water or it will kill the fish and whatever.
I believe the water applied version of Roundup is Rodeo.
I edited the original post with the correct picture.
JJ, I considered that attachment but I just couldn't justify it for 250' of bank that would be trimmed once a month or so. Otherwise that is a great attachment.
As far as planting low growing grass that's actually in my plans. I'm looking at Lariope to plant in this area. The trimmer would be used to keep things up for a couple of years until the lariope gets established.
Thanks for the replies.
/ Cutting grass around pond #6
JJ - We have used Roundup around our lake for years....We apply it from the boat with a pump up sprayer at the bank...none of it gets into the water by spraying from the water close to the bank and at the bank....It dries rapidly and then is inert as far as wash off...We have never had any fish killed or adverse affect in all these years....
I do think if you sprayed it carelessly from the bank toward the water and the wind was blowing toward the water , you would have a potential problem..
Just to clarify my pond is about 2-1/2 acres most of which I'm able to cut by mowing with my offset flail mower. It's only the levee end that's hard to cut because of the bank angle. That's why I'm looking for something a little easier than a weed wacker but nothing to high tech.
/ Cutting grass around pond #8
I use my Stihl Pole Pruner to mow the ditch when the state does not bother with it.
When I get ambitious I end up cliping about two hundred feet of the bank on the road.
standard summer use chain saw oil on the hedge clipper attachment is a must with
earplugs and a good hat !!!!!!!!!!!!!!!!!
My only mistake was buying the smaller unit without the extendable drive shaft.
The larger unit also has the longer cutter head which saves time and labor and the
shoulder harness helps with balancing it.
The shoulder harness is must for using it to carry the weight of the unit
/ Cutting grass around pond #9
Get a goat, and string up a line 250ft long with a sliding leash so he can roam from one end to the other end. I would say that's pretty low tech lol!!
/ Cutting grass around pond #10
A good quality string trimmer ought to work fine on a 3 foot wide strip. Is it so steep you cannot even stand on it? If not, it's only a few hundred square feet. Seems hardly worth it to purchase some kind of tractor mounted mower.
FYI, A great aquatic and landscape herbicide is Reward (diquat Dibromide). It's fast acting, kills anything green, and isn't harmful to fish or any other critters that call your pond, home.
/ Cutting grass around pond #11
Roundup will not harm your fish, but the surfactant in the mix will kill the amphibians in your pond. The frogs, toads and salamanders are an important part of the food chain in your pond and help in controlling the insect population. I will not use Roundup around my pond, I did once and it took years for the amphibian population to reestablish itself.
/ Cutting grass around pond #12
I have a conventional riding mower I use for just that purpose. Nothing special about it. It is one I have around and decided to use it.
20 hp but don't need that many ponies.
46" cut, 2 blades but don't need that width and I do like the 2 rather than 3 side discharge blades. Clog less.
I took the hood off it to lighten up the front ends which helps steering up hill without 4 wd. Works really well.
I bought a pair of ATV "Snow" tread tires for the rear. The snow tread has chunks of rubber tread widely spaced and half an inch or so high which do a great job of holding onto the turf; like spikes where you have a small surface area to support the weight of you and the machine. I usually wait till the dew is off to improve traction.
The tractor is light and this is part of the advantage in holding on the slope.
I sit on the side of the seat where my whole body is centered on the up side tire line. I sit on a cushion which makes it comfortable. Very stable and not the least bit worried about a roll over.
I have tried numerous things from tractor operated bush hogs to the DR ProZ where you can move the controls to the rear and use it as a walk behind. This works pretty good but I have to walk behind it. Besides having a lot of grass to mow at a 1:3 slope you are walking with one foot above the other and it is awkward and tiring.
I bought bar lug tires for the DR and attempted to use it in the conventional position but it weighs around 900# and is just too heavy to hold on the slope. Additionally, the bar lugs tend to slide sideways on the slope and don't work all that well. Turf tires are absolutely useless course they weren't designed for this application.
So here I put a pretty much unused lawn mower to use and for the $105 price for 2 tires off www including shipping tax and all, I got a machine that does the trick. You can't buy a hedge trimmer like shown in your picture for that. I put them on the stock wheels that were on the mower which were slightly wider (rim) than the tires. A real bear to get installed by myself, but having the wheel wider and them being 4 ply bias there isn't much sidewall flexing even at the 10 psig where I run them for riding comfort.......and I don't have to walk!
HTH,
Mark
/ Cutting grass around pond #13
I have the same situation trimming weeds on the levi of my 2 acre pond. Was trying to use an Exmark ZTR and got too close to the water`s edge which was slick. Mower (very heavy) started sliding into the water and I couldn`t hold it. Ended up totally and I mean totally submerged, hot engine and all, under water. Took me forever to dry it out get it running again. Now I`m happy to just use a hand held weed eater once a month. Geraldt
/ Cutting grass around pond #14
That's what I have been using on our 1 acre pond with 6 foot wide strip (needs two passes) at >45 slope. Lots of work and hard on the feet and back but only do it 2 times a year so it's tolerable.
/ Cutting grass around pond #15
I have the same situation around my pond, it takes a good $10.00 per hour man 8 hours to cut pond **** and twice a year. I ended up making this.
I have about $ 400.00 in it and more hours than I want to count. It also trims trees and bushes up to 20 feet. I have a video off it in action on my phone but it will not transfer says file is to large. It is by far the best attachment I own.
Well after a lot of pondering I decided on a long reach pole pruner with a 2' long 3/4" capacity sickle bar. The overall length is 93" long so I will now be able to sweep the grass while standing on top the levee. This is a commercial unit for large limbs and comes with a 7 year warranty so I'm confident it should hold up well cutting grass and weeds. It's a little heavy at 13.8 pounds but with the strap and speed of cut I should wrap things up pretty quick. The first trip will be to catch up on some tall weeds so this should be a good test.
I have the same situation around my pond, it takes a good $10.00 per hour man 8 hours to cut pond **** and twice a year. I ended up making this. I have about $ 400.00 in it and more hours than I want to count. It also trims trees and bushes up to 20 feet. I have a video off it in action on my phone but it will not transfer says file is to large. It is by far the best attachment I own. <img src="http://www.tractorbynet.com/forums/files/attachments/380033-cutting-grass-around-pond-sickle-mower-paint-008-jpg"/>
Man that is a nice rig. If I had more levee to cut I would definitely be in the market for one of those.
/ Cutting grass around pond #18
Can you give a brand or model for the pruner? Thanks.
Yes, It's a Tanaka model TPH-260PF. There are also several other mfgs that make the 59" shaft (93 overall length) commercial pruners for right at the same price. Stihl, Redmax, Echo, Husquvarna just to name a few. One correction on the unit I purchased is the bar is 22" instead of 24" earlier posted. Actually I'm a fan of Tanaka and their 7/2/1 warranty is hard to beat. (7 years residential, 2 years commercial, 1 year rental) Here's a couple of not so quality picks I found online. Untitled.pngimagesCAJ8MUYE.jpg
/ Cutting grass around pond #20
Very nice and seems to be well thought out. I really like your putting in on the loader where it is up front and easy to see what you are doing......but you knew that. Grin
The hydraulic pump to drive the wobble box ought to make the drive nice and smooth. Did you use a regular length sickle or shorten one? How far does it stick out from the tractor's wheels? I assume the slope is locket to and set by the cylinder, and the height by the loader. Do you have a float on your loader valve and if so how does it work.....aka does is slide across the ground as hoped or try to dig in due to weight? Where are the remotes located that power the unit? Using the ones on the rear of the tractor and just plumbing forward?
Mark
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
2019 GENIE S-40XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-40XC...
2020 BOBCAT T650 SKID STEER (A62129)
2020 BOBCAT T650...
New/Unused LandhonorQuick Attach Backhoe (A61166)
New/Unused...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A61165)
2002 Ford F-250...
2012 Volkswagen CC Sedan (A61569)
2012 Volkswagen CC...
