JD 175 hydro fender pan ?
   / JD 175 hydro fender pan ? #1
Rebs
Niagara Falls, NY
JD 175
I removed the fender pan and had it sandblasted and painted. I The cushions under the pan were rotted and fell apart when removing them. Does anyone know where I can get replacements and where they go on the bottom of the pan ? I did salvage one pad for the fuel line.
   / JD 175 hydro fender pan ? #2
I've used "stick on" insulation to replace those pads. You can buy what ever you need at Home Depot or any other good hardware store and then cut to fit.
Thank you Bruce
Does anyone have a picture or a diagram where all it should go ?
   / JD 175 hydro fender pan ? #4
On my 345 the pads were used to insulate the fuel tank from the metal frame and then between the fender pan and the foot rests --- just to keep metal from rubbing against metal.
7ft Metal Gulf Gas Pump (A57454)
7ft Metal Gulf Gas...
INOP/NON-RUNNING 1990 Ford F-150 Pickup Truck, VIN # 1FTDF15Y1LNA65905 (A57453)
INOP/NON-RUNNING...
2008 Sun Coastal 20' Cargo Trailer (A57148)
2008 Sun Coastal...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
UNUSED HOSTAGE AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED HOSTAGE...
