Loader hauling 1,000 lb bales with a small tractor
   / hauling 1,000 lb bales with a small tractor #11
Jim, RPW, Dave & Gary - you gave it your best shot. In certain cases its just a lost cause.
   / hauling 1,000 lb bales with a small tractor #12
Reminds me of myself. When the tractors out so is my boy!
BTW: my boy has the same boots in blue :thumbsup:
Thank you for the input! The straw in the bucket isn't that heavy as it is just a piece of the 1,000 lb bail. Only lifted the load for the photo. Didn't drive that way. Hooks are welded onto the bucket so the straps are not touching the bucket.
Thought it would be helpful to those who come home with 1,000 lb bails of straw. Especially if you have hooks welded to your bucket.
   / hauling 1,000 lb bales with a small tractor #14
I never thought it was a 1000lbs or your tractor would be on the ground.
   / hauling 1,000 lb bales with a small tractor #15
The pictures show otherwise....the straps are stretched tight around the edge of the bucket (well at least on the side we can see).
Why is your ROPS leaning back so far?
   / hauling 1,000 lb bales with a small tractor #16
Consider building a guard on the top of the bucket so objects can't roll back into your lap.
   / hauling 1,000 lb bales with a small tractor #17
Pretty sweet for a little tractor and your son will learn to be around tractors....don't worry about all these safety police ;)
It's plain to see you've never witnessed someone as I have confined to an electric wheel chair that had their spine CRUSHED from a raised rd bale that rolled back on them while sitting in the seat of a tractor! He told me he was mad at himself and wished it had never happened BUT IT WAS TOO LATE!!!!!!!!!!!!! ENUFF SAID!!!!!!!!!
   / hauling 1,000 lb bales with a small tractor #18
Smaller tractor will only handle 2 but speeds things up niceley loading 900lb hay 3 at a time !
Thank you for your concerns. It would be tough for the bale to role back into the tractor as there is a 2 1/2 foot receiver welded to the bucket for moving trailers in the yard. It would have to jump over this to dump on the cab.
   / hauling 1,000 lb bales with a small tractor #20
I had noticed that in your second photo of post one. Do you have a photo of the bucket without the bale?
Thanks,
Bruce
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2016 FORD Taurus (A50324)
2016 FORD Taurus...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
