What is the difference in the 5085M JD and the 5085E JD? (any opinions)
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #1
bmc000
Hodges, Alabama
5425 John Deere
I am looking to buy new open station with a loader. Any opinions would be greatly appreciated.
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #2
Welcome from Wisconsin
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #4
Welcome to TractorByNet!
I moved your thread to the John Deere Ag Tractors forum. :)
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #5
A couple thousand dollars. :D
Same engine.
E has a 12 speed transmission, M has a 16 speed.
The M is a little heavier tractor. From what I understand, it's the frame.
The M has a bit more lift capacity and increased hydraulic flow.
Here's a link to the TractorData pages for each:
5M
5E
I'm assuming that you've been to the Deere website already?
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #6
The differance I heard was think of it as the E series as a Homeowner version and the M as a professional version. The M is built heavier and to run long hours. Where as the the the E is basically used for doing small chores and such light plowing and such. Like others said the M is about 10-15K more depending on options.
James
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #7
James
Both machines are more then capable of very day hard work. They have same engine, think of it as buying a car with all the basic features and then getting one fully loaded. The m has a little over 2 gm more hydraulic output. Also has more lift capacity for
3 point. Loaders are identical. The M weights about 1000lbs more. I have a 14 85e and pull a mx 10, 14' off set disk and 84 tiller. For me I couldn't see spending another 10 grand for the extras.
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #8
. The M weights about 1000lbs more. I have 14' off set disk
I'm curious as to what type soil,what brand offset and do you pull that 14' plow with wheels raised with a 85 engine HP tractor? Where I live a 14' offset with wheels raised will load a 120-130 hp tractor.
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #9
Your info lists a JD5425, is it not up to the job?
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #10
It's a JD 210 disk. I was worried about it pulling it also. So far I haven't had a problem. Soil is loam with little rock. It has 23" wheels, I haven't had it in anything wet and heavy. The tractor has loaded tires and loader. Haven't had to use MFWD yet. Haven't had to put the tires down either, only had it to the axles a couple times, you definitely know when it does. This is a pipeline that is pretty hard pan. Still doing a decent job for being so hard. After going over twice it was digging good.
http://youtu.be/Mwhk3bJ8z94
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #11
JD 210 is a secondary tillage machine. 210 is not a true offset although it does have JD's double offset design that I learned to hate because in hard soil the tandem will follow tractor resembling a snake wiggling from side to side. Don't attach your 5083E to a true 14' offset raise the wheels and anticipate pulling it very far. Your tractor pulling a true 14' offset ain't going to happen!
/ What is the difference in the 5085M JD and the 5085E JD? (any opinions) #12
I been really happy with disk for what I'm using it for. I was really impressed with the tractor pulling it, it weights 2500lbs and digs really nice. I have a broken sod with it and does a good job. I'm sure in the right soil I couldn't pull this disk, little lone the one your talking about.
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
JOHN DEERE 7320 TRACTOR (A64278)
JOHN DEERE 7320...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2018 PETERBILT 520 6X4 T/A GARBAGE TRUCK (A66091)
2018 PETERBILT 520...
