Rear hydraulic hookup size on a XR3032
   / Rear hydraulic hookup size on a XR3032 #1
p95loser
Hi all,
Just purchased a LS XR3032 and want to run a grapple off the rear hydraulics. I am planning on ordering my hoses and fitting online because it is much cheaper but don't know which size and type male quick connects to buy to hook the rear in. Any help would be appreciated!
   / Rear hydraulic hookup size on a XR3032 #2
I ran my lines from the rear remotes to the front also for a hydraulic thumb I installed.
I bought all my fittings and hose from Tractor Supply. I used all 1/2" fittings and hoses. 3000 psi 2 wire ready made hose 14' long. 2 Swivel 90's. And bought 6 pkgs. of Pioneer couplers. I can't find where I posted my list. I must have replied to someone else with the list.
I found my list. I had replies to another post re" another members XR4046. I copied the list I gave him here.
"I just ran my hoses this past weekend. I used 1/2" 2 wire 3000 PSI hose. Here is a list of parts available at your local TSC store.
You will have to measure for the length hose you will need. I don't have any front hydraulic attachments yet just wanted to have the lines run for when I do. You can use 1/2" or 3/8" line but you have to bush the 3/8" hose up to 1/2" male pipe to fit the couplers.
My list
2- SKU# 1819884 - 168" (14') long 1/2" 2 wire 3000 PSI hose w/ male to male pipe each end
1 - 5006-4 - Double breakaway clamp with bracket to hold the front couplers
4 - SKU#1818626 - 1/2" male to 1/2" female swivel (or 1818105 1/2" male to 1/2" female 90's, your choice)
6 - SKU# 1824407 - VP4200-4 (or VP4000-4 your choice) 1/2" pioneer 3000 PSI coupler sets. (I bought some extra)
I also bought a 4' jumper hose I used to bleed the the lines. I can later use the 4' hose to connect to a front cylinder when I get something to install that needs hydraulics. I still have to get the rubber caps to plug in the couplers when not in use. They were out of stock.
I ran the lines under the tractor in between other lines and up to the front. I just used zip ties about every foot or so front to back. If your tractor is HST make sure you don't run the lines under where the pedals arms. I ran mine between the fwd and rev arms. "
   / Rear hydraulic hookup size on a XR3032 #3
Hi all,
p95loser, please let us (me!) know how you like your XR3032. I'm on a fence between this model and a G3033H. When I first started looking at tractors, I was considering the J series, then the G3033H, and now the XR3032H.
My dealer doesn't have the XR3032H for the to see in person yet.
Thanks for your help.
I drove both the xr3032 and the g3033. Hands down the xr was much nicer to me. It has the suspension seat, tilt steering, larger operator platform, 2 rear remotes standard, loader control on fender, larger frame, and heavier. I am not regretting my purchase one bit.
I also ordered my hydraulic hoses and got them installed today.
   / Rear hydraulic hookup size on a XR3032 #5
Very good information p95loser. I really appreciate your comments. Hopefully, I'm about a month from being able to make my final choice. Please continue to comment on your XR3032H as many of us would appreciate hearing first hand about your experiences.
Good luck with your tractor.
Cheers!
XCMG CV83PD (A53317)
2018 Ford F-350 Flatbed Truck (A55973)
2018 Ford F-350...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
MISC TIRES (A54757)
MISC TIRES (A54757)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
