Backhoe Bucket Size
/ Backhoe Bucket Size #1
lubepimp
Member
Ontario
JD X320, Kioti DK40SE HST
I think I`m finally ready to pull the trigger on a Kioti DK40SE tomorrow, just going through my checklist of haggling points....and reviewing all the great advice I`ve found here for that list. One thing I`m still unsure of in any way is what is a good size for the backhoe bucket for ``general` ùse. Stump removal, digging holes for planting trees, ditching...anything else I see while I`m on the seat lol. It seems price won`t be an issue as the dealer indicated he`s already including àny size`bucket in the BH price. Any thoughtsÉ Cheers, Tyler
/ Backhoe Bucket Size #2
You'll need a 36" if you want to dig graves. :D
Other than that, it's really up to you.
I don't have a clue about that tractor and backhoe. All my experience has been with commercial TLB's.
But, generally, a narrower bucket will give you more force to grub stumps or dig in very hard ground. A wider bucket will move more dirt per bucketful, up to the point that the load is too much for the hoe. (then, it will just slow you down)
If you want to dig a ditch to stand in, for instance, while you're laying pipe, you need a 24"
/ Backhoe Bucket Size #3
For general purpose use an 18" for an 8 1/2' backhoe
A 12" works better for stumps.
/ Backhoe Bucket Size #4
For my B26, I have a 12" for normal digging and a 18" cut down to a 7" for trenching. I bought the TLB used and the original owner bought the 12 &18 buckets but quickly found that the 18 was too large for the tractor in most digging instances so he cut it down to a 7" which is plenty wide for trenching in small water lines. I think I would have made it 8" minimum though for a little easier damp soil removal as the 7" clogs up pretty bad in wet conditions.
The 7" does work well for cutting roots on stumps when digging one out. It has almost twice the power as the 12" and will readily cut thru a large root that the 12 wont.
You may want to look at getting two buckets with it. Depending on what you plan to do with it. A 12" is perfect for digging holes with my tractor but a much wider one would be nice for cleaning out ditches
hmmmm, from the sounds of it I may need to start considering more than 1 bucket. There's actually only 3 stumps currently that I need to remove, may be more in the future as I plan to "rent" myself out. Immediately I will be doing more digging and rock removal (big field stones)....with a hydraulic thumb would a 12" bucket handle stones 2'-3' in diameter?
/ Backhoe Bucket Size #6
I have a 12" on my compact tractor and it seems to be just right for normal homeowner projects like digging holes for transplants, digging out stumps and the occasional trench for water lines.
/ Backhoe Bucket Size #7
I have a 12 and an 18 on the 3pt hoe on my Ferguson. I'll be buying a new tractor soon and have been torn by this question as well.
I use the 12 way more than the 18 as where I dig mostly, are many many roots and stumps. The 12 goes thru the roots and is the bucket of choice for stump removal. I've done a lot of trenching as well and very infrequently do I need the 18.
I think I will get a new 12 and see if my current 18 will fit the new rig, or I'll try to make it fit.
/ Backhoe Bucket Size #8
Soil type where you would be doing most of your digging is determining factor of whether tractor can handle it. I have some soil (well mostly rocks) where I can lift the tractor off the ground with the 7" bucket and not have the bucket pierce the soil more than 2" (the tooth length). Some folks with a sandy loam might easily use an 18" bucket that they could load up easily.
I think every TLB owner should have at least 2 bucket sizes. I would start with a 12" and then see if I needed to go up one size or down one size.
I really like the 7" size for trenching, other than wet dirt compacting in it, it is perfect size. I can drive across it without my wheels dropping off in it too bad which is good for mating up to a ditch, so I don't have to walk the tractor across a wide ditch on the FEL bucket and backhoe.
/ Backhoe Bucket Size #9
AS others have stated the job at hand determines the bucket size. IF it wont hurt your budget too much it might be wise to try and get a good deal on a second bucket along with the purchase. For most of my needs I can get away with the 18" but I will eventually need to get others. Also you might want to look at getting some of the big foot pads for it from the start as the hoe will pull the tractor around without them.
/ Backhoe Bucket Size #10
For ripping out tree roots, nothing is better than a ripper tooth instead of a bucket. In your case, I think I'd buy the 18" bucket for removing dirt and I'd think about buying a ripper tooth to rip out the roots.
SO I have a question re: ripping roots. I don;t have a lot of stumps to remove immediately...maybe in the future if I start working for hire....I've never actually used a BH for stump removal. Always have had to dig around with a spade, cut the roots with axe or chainsaw and then pull out with a tractor or pick-up.
If I can't get through the root with the BH bucket, is it not feasible to lift the root out some with the bucket then fire up the chainsaw to finish it off?
/ Backhoe Bucket Size #13
Likely as not, if you can lift it up, you can break it with the back hoe. You could manage OK with a 12" but just have to dig further out so the root isn't as big. I like my 7" because it is much easier to cut thru a root with the smaller bucket and then use the narrow width to get in between stabilizing roots and tap root to remove more of the dirt. I can dig them out with the 12", but it takes longer than using the 7". The 7" is custom made by cutting down an 18" by original owner. I think he found quickly that the 18" was too big for the little B26. My super hard ground with lots of rocks is a chore on the 12" digging with it. Your soil may be much softer, if its any harder if would be a replacement for concrete.
I have very rocky, dry soil as well - so smaller would be better?
/ Backhoe Bucket Size #15
my soil is hard and rocky. I've ripped out many many large stumps with my 12 inch. If I had a smaller bucket, I wouldn't even mount it.
As I said before, the 12 in does about everything I need to do. I very seldom use the bigger one.
/ Backhoe Bucket Size #16
I modified my 5' front loader bucket to fit the BH77 backhoe, I like it 'cause I can take out two stumps at once. Just sayin'
10" and 24" - - thinking about getting an 18" as well, wish the hoe had quick detach for the bucket. Does have a mechanical thumb that I'm going to convert to hydraulic.
bumper :c)
/ Backhoe Bucket Size #17
I have an 18 inch bucket that was taken off and never used has I 1/4 pins I don't need it so if anybody interested private message me thanks
X-CEL GOOSENECK TRAILER (A62130)
X-CEL GOOSENECK...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2001 KUBOTA R520 BACKHOE (A62129)
2001 KUBOTA R520...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63118)
2004 Cadillac...
2019 CAT 259D (A60462)
