Odd rockshaft behavior
/ Odd rockshaft behavior #1
jeepinator
Gold Member
JD 3520, JD X739
I seem to be the king of odd tractor behavior :D
It just started doing this perhaps 4 operating hours ago. I noticed it when idling and off the tractor doing something. Basically, the hydraulics start hissing (like you are making verrrry minor inputs) very softly at first, and then louder, and then it lifts up an inch or so. Then it's quiet for a period. Repeat. Forever.
Now I am noticing it when moving and doing stuff.
I think, atlough it's really hard to tell, that it's falling very slowly, and cycling back up.
What is causing this?
I think it's getting worse, but can't be without my tractor for the next few months (or so it seems!).
I checked the fluid levels and they are good.
/ Odd rockshaft behavior #2
What kind of tractor? Sounds like your hydraulics are building and losing pressure. Start by changing the filter and cleaning the screen in the belly if it has one. Does it have a loader?
It's a 3520 w/ 300CX.
~120 hours
Thanks for the tip. I'll pickup a filter.
What is this screen you speak of?
/ Odd rockshaft behavior #4
Hi jeepinator,
I have a 3320 thats been doing that since day one! Never thought anything was wrong...
It hasn't gotten any worse for sure in 200 hours.
Any other 3x20 owners notice this?
/ Odd rockshaft behavior #5
guys, my 3520 has around 20 hours. it also makes these odd sounds coming from the area of the 3PH. i havent noticed it lowering or raising, just makes odd sounds from time to time. i just figured it was normal for hydraulic lifts to do so. maybe there is more to it. should i have my dealer(60 miles away) look at it?
/ Odd rockshaft behavior #6
Although I've never noticed mine lowering, it does make this noise when fully raised. When this happens, I can move the lever just slightly forward and it will stop. It's as if it is trying to raise the rockshaft beyond it's limits.
3320 eHydro - 18 hours. I thought it was just the nature of the beast.
I put a few hours on it today and it's definately getting worse.
Another observation: Previously, I could leave the 3 point hitch raised and come back days later and it would still be raised (although I always lowered it if I remembered to). Not any longer. It falls inches in minutes.
This would be majorly annoying problem #2 for me.
Good thing for warrantees :rolleyes:
/ Odd rockshaft behavior #8
I have noticed that my FEL creeps down if it is left parked without the engine running. But have not noticed the rockshafts doing it. I will have it checked and get back with you on it. Tractor is at a JD dealer right now having additional hydraulics installed. I
/ Odd rockshaft behavior #9
On my oringinal (2000 mod yr) 4300 I had this problem. It made grading a real pain. It was in dealership under warrenty a few times as it kept getting worse. Turns out that JD had a design issue and issued a PIP. They cleaned and purged the hydraulic systen and installed an in line high pressure filter that took care of the problem. According to the mechanic, the problem is that the rockshaft valve is very picky and any particle causes the leakoff of the cylinder to the point that the rock shaft valve opens and the cylinder picks back up to the set point. On mine it was quite sudden. This is an adjustment about how far the arms droop before the valve opens. The smaller the distance the less movement but more cycling with noise. The larger the fewer but the bigger the correction.
You might want to check to see if you have the HP filter in the hydraulic line going to the 3 point.
/ Odd rockshaft behavior #10
I spoke to the JD dealer where my tractor is today and they have not heard of this happening with these models. They asked me if I had heard of a fix to the problem. They will check mine out while they have it apart.
/ Odd rockshaft behavior #11
Billyo, I think you have a problem with the adjustment of your linkage. It is doing precisely what you think it is. When it is adjusted properly, you should be able to lift the draft arms another 1/2 inch or so. It is now going against the stop and putting the system in relief. It is a simple adjustment, but make your dealer do it if it is in warranty.
/ Odd rockshaft behavior #12
Jeepinator, It sounds like you have a bad seal on the lift piston or a defective control valve. I haven't seen 3000 series with this problem yet but someone else might have.
/ Odd rockshaft behavior #13
I also have 3320 it had the same problem. The dealer came to the house and could not find the problem. So I took it to the dealer where it stayed a week. When I picked it up it stil had the problem. To make a long story short I had to fix the problem my self. The problem is the relief valve on the three point hitch. It is not sealing right I took mine apart myself and recut the seat. The dealer can just install a new one. This will fix the problem.
Thanks for the info everyone.
If it lasts until summer's end, I'll be sure to have the dealer fix it under warranty. Having a dealer fail to fix something would make me pretty angry. That kind of stuff gets me fired up. They'll fix it to be sure. And smile about it too :D
/ Odd rockshaft behavior #15
I'm also having problems with the rockshaft on my 3720. 26 hours on the machine, but I just started using the 3pt. 3pt raises at a 'normal' rate, but the drop rate was getting progressively slower over use time. Adjusting the rate control valve didn't seem to affect the drop rate. It was taking minutes to lower a rotary cutter. Frustrated, I decided it was a good time to take a coffee break and shut the machine off. After my break and referencing the manual, I started the tractor back up and the rockshaft was working to my satisfaction. Not for long. It went back to the previous slow drop rate. On level ground, I set the park brake, put the machine in neutral and operated the rockshaft from the ground where I could clearly hear a hiss/and the sound of what I perceive as a strained hydraulic system. It was a different noise than when the rockshaft drop-rate valve is in a locked position and you try and operate it. It sounded more like an issue on the suction side. I then started to fool with the drop rate valve, and cycled it from slow to fast (to the stops) numerous times. Afterwards, the rockshaft has been working flawlessly and no hiss. I'm speculating that a partical was clogging the valve. I'm planning fluid and filter change at 50 hours when I do the oil. I'll post back to share my findings, or if the gremlin comes back. Other than that, I've been real happy with the tractor.
-Gary
/ Odd rockshaft behavior #16
I have a 3320 and have not had this or any problem with the rockshaft. I have about 105 hours now.
Billyo:
JD110 mentioned that you should have your rockshaft adjusted so it doesn't hit relief when the lever is all the way back. The reason your tractor and mine behaves this way is because we have backhoes. When the dealer installed my 448, they set the stopping point of the rockshaft to match the exact point that you would install the pins for the backhoe while mounting it. Otherwise, everytime you were mounting the backhoe, you'd have to play with the rockshaft lever to find the right spot that would allow you to slip the pins in. I figure we've lost very little in the max height we can raise the rock shaft (have had no issues with any of my impliments) and it's easy enough to not pull the lever back all the way to avoid hitting the relief point. I much prefer it this way since the backhoe mounts in a snap. Just wanted to give you something to think about before you decide whether or not to change it back.
About a month ago I finally sent it in for repair (along with a broken locker mechanism and leaking front axle seals). I am stupid for not knowing exactly what they did to it. I was a bit busy when they returned it, etc.
But basically it still does this burp thing, but with much longer intervals and no noise. And it is much less noticeable. I am sure it will get worse with time, but I still have a year left on the warranty.
/ Odd rockshaft behavior #18
I have a 3320 with 130 hours and have not see or heard what you are describing, hissing is fluid passing somewhere eather thru a spool or a check valve and if you are not engaging and handles I would call that not normal! I work offshore and we use a lot of hyd's. My concern with that type of behavior on any hyd system is wear and my experence is that type of thing just gets worse with time. May be just a simple adj to get everything aligned properly with all handles in the netural position but I would get it back to the dealer while it is in warranity
/ Odd rockshaft behavior #19
Sadly, this thread now applies to my tractor. With any implement hanging off the iMatch the 3 point cycles leaking down slowly with a hiss followed by a rapid reposition up. It doesn't matter where the rockshaft lever is positioned or what the engine RPM is snd for added fun I'm out of warranty.
/ Odd rockshaft behavior #20
Dan Hunter
Your tractor 3 pt problem could be rockshaft piston seal or control valve failure.
2016 CAT 308E2CR EXCAVATOR (A67714)
2016 CAT 308E2CR...
Has compression. Unknown operating condition. (A64553)
Has compression...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
