JD 4030 air conditioning compressor not engaging
/ JD 4030 air conditioning compressor not engaging #1
jeffharp
JD 4030 3010 Case 1835C
Hello,
I am having a problem figuring out what the compressor is not kicking in. I am not getting power to the compressor. So I tracked it back and determined that I was not getting power to the thermostat in the cab. One of the wires going to the thermostat comes from the blower switch. Since no power was going to the thermostat, I assumed the blower switch was bad. I replaced it, and the same result.
Probably unrelated, but there is no power going to the radio and one of the blowers does not work when on high.
Am I on the right track? I do not have a wiring schematic, so any help would be appreciated.
Thanks jeff
/ JD 4030 air conditioning compressor not engaging #2
Hello,
Thanks jeff
It could be a pressure switch that is not letting power threw. on the blower there is a resistor that goes bad and want let it blow on high
/ JD 4030 air conditioning compressor not engaging #3
Bad cab connector under the right front corner of the cab when sitting in the seat. Remove filler plate at the rear of the right side battery and the connector is behind the filler plate.
I will take a look tomorrow. Thanks
Once I get it cooling I will work on getting the blower working right. How do I get to the
blower?
/ JD 4030 air conditioning compressor not engaging #6
blower?
Raise cab roof then remove a bunch of screws that attach a metal cover to access blower motor,evaporator & heater core. On AC not working 1st thing I would do is check the coolant(freon) pressures before looking for something electrical
See the connector. Which wire should be supplying the power?
/ JD 4030 air conditioning compressor not engaging #8
I agree with Jim on this as most systems I have seen will disconnect the clutch to the compressor if it gets too low on Freon. Curious is this an R12 system or has it been converted to R134a?
/ JD 4030 air conditioning compressor not engaging #9
The terminals burn in the connector. There is two power wires to the top of the cab from the connector. The blower motors on low speed split the power through one motor then to the 2nd motor from one wire to run at half speed. On high speed each blower has its own power. If there is no power for the AC clutch and one blower motor on high, one of the power wires has no voltage.
/ JD 4030 air conditioning compressor not engaging #10
The AC compressor has a thermal limiter (fuse) at the compressor that burns out if low on freon, little square black box with three wires under the compressor. Check to see if if it is melted or if there is power on one of the three wires with the AC on. If no power, check the cab connector. If both blower motors work on low speed the motors are OK.
You hit it on the nose. Initially I was thrown off by the power at the blower switch, until I found out that there was power also coming from the right side blower into the blower switch to run the left blower on the low setting. As I was tracing it back to the tractor firewall, I found the wire that burnt in the connection. Fixed that and i was good to go.
Thanks for all the help!
Jeff
Front Tank Bracket (A64127)
Front Tank Bracket...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
1996 Champion 540P (A64126)
1996 Champion 540P...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
