Hi all, I've finally got close to buying my first tractor... however...
It's a 1980ish B8200 HST 4X4 with a front loader but here's the kicker, it has issues. The deal is right at $2700.00 but they say it's leaking fluid from the rear badly, the engine is solid, the HST will only work properly in LOW but it trys to working high range but just can't quite get started.
They also say the hydraulics for the loader works good as long as it's in low range.
Now, I know I'm asking a loaded question but is this something I want to consider? If it's just seals, air leaks, etc. then I'll make out like a rose but if it's the pump, crack in body/transmission then I'm screwed. I can work on engines and electronics all day but HST's are new to me.
It's 2 hrs away from me and I have not inspected it yet. It only has 749 hrs on it too.
I guess what I'm asking is, if it were you, would you even look at it or run like mad?
Thanks!
Thanks!
