ford 545 loader problem
   / ford 545 loader problem #1
mce
manteca,ca
ford/545
what would make the loader bucket continue rolling back all the way to the stops after the handle is in neutral position ? Thanks ahead of time............mce
   / ford 545 loader problem #2
Bad valve.
   / ford 545 loader problem #3
Welcome to TractorByNet!
We moved your thread to the New Holland Owning & Operating forum. :)
   / ford 545 loader problem #4
How about valve lever not centering in neutral.
Maybe leaking/worn spool.
I've taken the loader control valve apart, one spool slides / moves nicely . The other I had to use a dead blow hammer to r &r the spool . It' like the loader is not getting any hydraulic oil................Wher is the hydraulic res. for the loader???????????????????
   / ford 545 loader problem #6
I take it the valve end caps are off when you are trying to move the spool? I say this because the loader spool (LH in picture) has a float detent and the bucket has a return-to-dig magnet assembly (upper RH box). Rust can build up or parts can come apart and jam the spools.
The loader hydraulic tank and pump is in front ofbthe radiator accessible by removing the grill. The hydraulic fill and filter is accessible by opening the engine hood, then opening the hydraulic cover on the nose.
Later, emissionized tractors have a RH mounted hydraulic tank on the loader post.
   / ford 545 loader problem #7
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
