kubota m5100
/ kubota m5100 #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
A friend of mine has a Kubota M5100. Looking at the loader valve ports, there are different colored dots... orange dot, green dot, yellow dot. Each of the hydraulic hoses that connect to the loader valve also has colored tape that match up with the colored dots on the valve ports Can anyone tell me what the different colors mean ? Is orange high pressure, green return, yellow ??? Am I making any sense in what I'm asking ???
/ kubota m5100 #2
Any particular reason you are worried about it? Adding hydraulic plumbing? I dont think there is an industry standard coloring. Just match up colors. My l3200 has similar colors, but I didn't trust the colors for my upgrades, I used the letters/symbols on the valve ports & what not.
/ kubota m5100 #3
I have the same tractor. I believe the info is in the owners manual.
/ kubota m5100 #4
its so you know which hose hooks where
/ kubota m5100
Just trying to figure out which 1 (color) to install a T on to get High pressure somewhere else
/ kubota m5100 #6
For open center hyd's such as the M5100 has one can not TEE into hyd system to attach another hyd function but must attach extra valves(components) in series. One needs to continue hyd pressure to add other components at the PBY port on loader valve. Colors of hoses/fittings are just for identification for connections very similar to traffic lights or electrical connections in wiring harness's/diagrams
/ kubota m5100 #7
Adding another circuit can be simple - but sometimes it's not. Generally the green one is the pby port on your loader valve - it's a high pressure supply that goes to the hydraulic block to power the 3p hitch arms. If you need another circuit, you can send it to the "in" port of another valve instead - and then run that valve's pby (power beyond) port to the block.
If all this makes sense then good. But if it is confusing then keep reading about power-beyond until a picture starts forming. The simple version is this - each hydraulic circuit needs to be independent - we don't want high load in one to influence the operation of another. Power beyond makes it possible to keep connected loads from interacting. If you just tee in another circuit you may get unintended response under load that could
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2000 Volvo Semi (A66285)
2000 Volvo Semi...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
