Box Scraper Skidsteer Box Scraper
/ Skidsteer Box Scraper #1
McCaskey
East Aurora, NY
I added a quick disconnect plate on the back of my box scraper. My intentions are for grading & leveling with the skidsteer and pushing mulch into piles with the tractor. Still has the 3 point links for normal usage.The QD plate needed to be mounted high allowing the rear scraper door to hinge, but that required extra diagonal braces and removing the SS door when being used. Sandblasted & powder coated at a local shop. Extra weight should help when used with tractor 3PT. Overall, seems like an easy option for the OEM to offer.
(Re-posted content from Construction Forum)
XDSC07077.jpg XDSC07092.jpg DSC07811.jpg DSC07814.jpg XDSC07815.jpg DSC07826.jpg 0521121522b.jpg
/ Skidsteer Box Scraper #2
Wow, nice work! How much did they charge to powder coat?
/ Skidsteer Box Scraper #3
Great job! I can imagine having the box blade attached to the front of your CTL would really help when you need down pressure plus the ripper teeth are great for removing roots. :thumbsup:
/ Skidsteer Box Scraper #4
Nice work, let us know how it works out in use.
/ Skidsteer Box Scraper #5
Might call that thinking outside the "box".
Have you considered the patentability of your idea?
/ Skidsteer Box Scraper #6
We need an update. How did it do over all? Does it tend to go deeper when pushing in hard dirt?
I pull mine in reverse, and have thought about doing what you did, but it is far down on the list of projects.
On a Tilt-Tach and a 3 point adapter.
/ Skidsteer Box Scraper #7
Xfaxman, you've got some of the coolest toys . . . err. . . tools.
/ Skidsteer Box Scraper #8
Thanks, they sure are fun to use. :thumbsup:
This is another cool tool box blade machine. It can do it on the front or the rear!
Then there is the smallest cool tool 4' wide box blade.
The box pusher works great, although visibility from the drivers seat is a problem. Can't really see the angle or amount of material being pushed. It produces a very level grade because the tracked machine is riding on level surface after pushing.
I also tried used a three point adapter for pulling the scraper, but the reverse stress bent the pins on the tractor quick disconnect and broke the brackets on the adapter.
Sometimes I just grab an I Beam and drag it backwards with the arms in hydraulic float
/ Skidsteer Box Scraper #11
I never thought about that possibility. I think my brackets are thicker, but I will keep an eye out for cracks.
6053 (A61165)
6053 (A61165)
New/Unused Landhonor Grapple Bucket (A61166)
New/Unused...
UNUSED MGY-100KW FUEL HEATER (A62131)
UNUSED MGY-100KW...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSENECK TRAILER (A59909)
2022 BIG TEX...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
