Familyroom Addition on our Cabin
   / Familyroom Addition on our Cabin #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Afternoon Guys,
I am at it again so to speak, the last big project was the barn that I built about 3 or 4 years ago.;)
Kathleen and I have wanted to expand the size of our cabin for the last few years and are finally in the process of making it a reality. We discussed many options and locations of which side of the house to build on, before deciding on the right side.
Since we are on a slab, we ruled out the left side because of water drains and septic lines, and the 1000 gal holding tank is only about 20 ft out from that side. It could have been done but would have made the job a bit more difficult. The well water line comes in from the back side of the cabin, so again, did not really want to contend with that either. Also another major consideration was maximizing the view from whatever location we decided upon.
The foot print of the cabin is 24 ft wide by 28 ft deep, and many years ago we put a 10 ft by 20 ft porch on the front for fair weather enjoyment ! :) We have enjoyed that porch immensely through the years.
So through many discussions between ourselves and our friends, we decided on the right side, going out 18 ft from the house and of course the full depth of the existing house 28 ft.
I apologize for no site work and foundation pics, but we tied into the existing slab by hammer drilling holes and installing rebar rods to tie the slabs together. The outside perimeter concrete is 12" thick and 6" for the rest of the pour. After excavating and installing the forms we leveled and compacted the area. It gets quite cold up here in the winter so we insulated the floor with the 2" thick blue board insulation. We poured 4000lb mix to be safe.
The walls are 2 by 6 construction, and we are using truss construction spanning the 28 ft distance. So the new peak will be 90 degrees to the existing house peak. With an 8/12 pitch on the trusses we will get another bedroom above the family room, 14 ft wide by 17 1/2 ft long. We are planning on using this bedroom.
We decided on Anderson sliding windows. In the first picture, the front wall we will have two 4 ft by 5ft windows on either side of a 6 ft atrium door. Lots of glass to maximize the view. The long wall will have four 5 by 5 windows. And the back wall will have a 4 by 5 in the corner and then a 36" entry door and closest to the house and at the base of the stair case we will have one 3 bt 4 double hung.
OK I have a bit of a problem, I took the pictures with my I Phone and can not upload them onto this page with the aspx file extension. Help !
I will try posting the thread and uploading the pics by sending them later..... :confused:
Sorry for the delay on posting the pics, I called my son who is in the computer science field for some help with the pics.
I have never had any problem when posting pics using my Kodak camera but for some reason trying to use iphone pics is creating a bit of a problem.
Will try and get them posted tomorrow !
   / Familyroom Addition on our Cabin #3
Sounds good Scotty. Looking forward to the pics.
My how time flies if your barn build was 3-4 year ago. :)
Good Afternoon Dave,
Lets try up loading some photos !
First pic, looking at front of addition, second pic looking at rear of addition, 3rd pic inside looking at front corner, 4th pic inside looking towards the barn, 5th pic looking at the right side, 6th pic looking at front right corner...
Sorry for the delay on posting the pictures...:)
Trusses will be next ,,,,,;)
   / Familyroom Addition on our Cabin #5
Looks nice. You have a BIL in the window business? :laughing: It's going to be a very daylight room with nice views.
   / Familyroom Addition on our Cabin #6
Looks very nice, and well thought out…Beautiful country side Tony
Looks very nice, and well thought out?eautiful country side Tony
Good Morning Tony,
Thanks, so far the project has gone pretty well considering that the weather in new england does not always cooperate. We cant get a crane for the trusses until the end of the week so that slowed things up a little bit.
We did manage to get the left roof torn off and reshingled while waiting for the crane.
Dave, yes all the windows turned out to be expensive, but it would be a shame to stand in that room and not take advantage of the views !:)
   / Familyroom Addition on our Cabin #8
Congratulations on an exciting project!!!!! We're hoping to do something similar next year. The planning is all done, it's just a matter of finishing off some other projects before we start a new one.
I'm a big fan of using lots of lumber in framing and believe you can't use too much, but your bottom and top plates have be wondering what you are doing? From the pics it looks like three layers of bottom plates and four top plates. Are you adding height or is their a structural reason for this?
I'm also wondering why you didn't wrap the house? Air infiltration is where most heat and cold air is lost and house wrap is really a very inexpensive way to seal the walls from wind getting in.
Eddie
Eddie
Good Morning Eddie,
Thanks !
The bottom plate is pressure treated and bolted to the slab with the foam foundation seal sandwiched in between, using J bolts.
That top 2 by 6 is going to position the end truss and then we are going to strap all the other trusses with 2 by 4's in the floor for strength.
The walls are 2 by 6 so plenty of insulation to keep out the cold air, I did the same thing in the shop section of the barn, and its pretty darn tight even in cold windy winter weather.
In the barn I packed insulation all around the windows before I finish trimmed them out, no drafts at all...
Will post some truss pics soon ! :)
OK sorry, so what we do is bolt that bottom plate to the slab, and then lift the wall into position with enough over hang on the T 111 to extend past the PT bottom plate.
   / Familyroom Addition on our Cabin #10
Scotty,
It is looking great. When finished it will look like it has always been there. Are you extending the porch all the way across?
David
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A55787)
2024 AGT LRT23...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
UNUSED LANDHONOR LHR-SP50 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
Two Post Car Lift (A50120)
Two Post Car Lift...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
