CobyRupert
Super Member
Could just be a simple as a leaky door seal that lets cold air seep through, that when it hits the humid room air condensenses it and drops the water out of it. Check the seals and push the door closed tight.
Mold is easy to kill with household bleach.
It's not important whether the freezer has a heated door, or if the door seal has an issue. There would not be that much moisture condensing on it, unless the humidity is high.
The OP has said the basement is humid. Getting the humidity down to 50% or lower is the only thing I would be concerned about right now.
:banghead: Ughh. You may get the humidity down to where leaking cold air escaping doesn't condense water out of the room air. But your wasting so much energy running a leaking fridge and a dehumidifier, when the problem may just be the fact air can move between the cold inside and the humid outside. Seals.
OK, so the basement is MUCH, MUCH dryer!
Things have dramatically improved. I've got the hose hooked up and the dehumidifier runs constantly. I've got my last two fans running constantly also.
Right now the lowest reading I've seen is 60%. this is Virginia, and it is spring so some humidity is inevitable.
When do I decide it is good enough and only run it on an as needed basis?
Just asking...
David
Mold is killed by contact with household bleach. But is only effective on non-porous surfaces
If the surface is porous, like wood, or cinder block, bleach is only effective on the surface mold. This is because the VOC's that kill the mold mostly evaporate before they can soak into the pours. What is left after the VOC's evaporate is mostly water. Which can help propagate the next batch of mold, requiring future treatments.
Bleach is also toxic, and smells bad.
It's better to use a product like Moldex. It's very effective, has no offensive odor, and inhibits the return of future mold.
We live in a pretty wet area........I just bleached the eves of our house and the cedar shake siding. We had some little black mold dots appearing under the eves and some shake was starting to turn black. After the treatment......eves are white.....looks like we just painted and the shake looks new. As for humidity......some boat owners use a dryer/dehumidifier product like the one below......I use one in our travel trailer.....works well.....never have a moisture problem with it.
Bleach is good for killing the black spots but I think it is also a bit corrosive on wood so a good rinse is required. As for travel trailers, my in-laws were snow-birds. They didn't scrimp on their RV's but did scrimp in most other things. Epson salts sewed into cloth bags...apparently the salts soaked up a lot of moisture. When saturated the bags became rock hard...take them outside in the sun and get them back to epson salts with a little dropping/banging and start over. Their trick, not mine.
Yea.....a good rinse is required for the bleach. Up here......people use bleach for roofs, driveways, fences and houses. Works well but good rinse is required.
