CK25 Light on the dash after Winter? Can't find in user guide
   / CK25 Light on the dash after Winter? Can't find in user guide #1
MTUser
I am cleaning up my tractor after plowing to get it ready for the change over to mowing, and I have a light on the dash that I don't know what it means. I tried going through the user guide from Kioti, but I don't see it anywhere. Here is a picture:
This light came on once or twice very briefly when I was plowing, but went out. Now it is steady on for 5 minutes at start up. I haven't moved the tractor. I am not sure what to do.
   / CK25 Light on the dash after Winter? Can't find in user guide #2
Check your battery and alternator connections. Wild Guess??
   / CK25 Light on the dash after Winter? Can't find in user guide #3
Level of fluid in the coolant reservoir
   / CK25 Light on the dash after Winter? Can't find in user guide #5
After you correct the coolant level, you might want to check the snugness of your hose clamps. The extreme cold, like this past winter, can cause minor leaks at the clamps. Once engine is warmed up, metal expands, leak stops. Doesn't happen so much with new hoses, but after a few years of use the rubber looses it's elasticity....check it out....Hill Billy Bob
   / CK25 Light on the dash after Winter? Can't find in user guide #6
Wild guesses don't even come close.:eek::):cool:
Great suggestion. Thank you. I'll be sure to check it out
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
Teak Wood Dining Table (A55853)
Teak Wood Dining...
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
