Cut for hay with BCS tractor
/ Cut for hay with BCS tractor #1
rickyd79
Hohenwald, TN
Multiple BCS and Grillo walk-behind Tractors
I am planning to cut some pasture for hay over the next few weeks. I have not done this before so I am looking for any advice on this. I am cutting with my BCS 853 tractor and 59" dual action cutter bar. After I cut with my cutter bar how long do I let the grass lay on the ground to dry before running over it with my Molon hay rake? After it dries and I rake it into rows with the Molon hay rake does it need to dry out any further or is it then ready for baling? I don't have a baler myself but am hoping to rent a friends Caeb round baler to use on my 853. Any advice will be much appreciated. I don't want to end up with moldy hay for my equine do to not letting it dry long enough!
/ Cut for hay with BCS tractor #2
Going to depend on the weather, of course, but figure two days at a minimum unless you tedder it.
/ Cut for hay with BCS tractor #3
invest in a hay moisture meter and you will have no problems.
you need to see if you can find someone that can wrap your
mini bales for youto preserve them better too.
/ Cut for hay with BCS tractor #4
You want it to dry as fast as you can get it to. when it is mostly dry but still has some damp places by feel rake it so it will be moved around and the damp places dry quicker. Then go to the field and grab a hand full and twist a rope out of it, bend the rope and smell it, it should smell like good hay, not grass. Hope this helps. that was my way for years.
Thanks guys for your advance.
/ Cut for hay with BCS tractor #8
Just wait until the hay feels absolutely dry to the touch and in the small bales you have it will be fine. I would rake it when you are ready to bale it. You can rake it early as that rake leaves it light and fluffy so it will dry some in the windrow and bale later in the day.
thanks Creamer
/ Cut for hay with BCS tractor #10
What should the moisture content be? 10%...5%?
Thanks,
Bill
/ Cut for hay with BCS tractor #11
Moisture content in hay can vary depending on what type and how you plan to store it. Since the OP is using a BCS, I will assume the small round bale. I would store under cover or inside, and if so, moisture content at baling can be 15-20%, lower the better. Standard small bales, probably need to be 15-18%, and big round bales need to be 15% or less. If moisture is a little to high, hay will mold or be dusty, if really damp, barns will burn down. Hay loses moisture in storage, so air flow can be important. It will dry down to about 10% in dry storage after a month or so. The small round bales will dry out in storage better because you cannot stack them quite as tight. Hay needs to be dry before baling, but if too dry leaves will shatter and be left on the ground, and that is the feed value. So, a little moisture is necessary, especially with alfalfa or clover, but too much will result in mold hay or worse. (Hay stored outside, even big round bales can lose 30+% of feed material and feed value-Store inside or under cover off the ground)
Comes from 30+ years as a Ag Extension agent.
/ Cut for hay with BCS tractor #12
Let it dry one side, rake it so that the wet side is up and can dry in the sun in fluffy rows. Rake it one more time and when completely dry - bale. Bale too soon and the moisture ruins the hay.
If it has been out overnight before it had time to dry, the morning dew needs to be dried as well.
LOOK! (A63111)
LOOK! (A63111)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
Kubota KX080-4 Midi Excavator w/ Hydraulic Thumb (A64047)
Kubota KX080-4...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
1996 INTERNATIONAL 4800 SPREADER TRUCK (A63291)
1996 INTERNATIONAL...
