New fuel storage/dispensor
/ New fuel storage/dispensor #1
Teikas Dad
Gold Member
Live Free or Die
Kubota B3200
I finally finished my fueling station. The end product is based on what I've learned here on TBN from all of your experience and suggestions.
Early on I decided to go with a 30 gallon tank. I figured that it's small enough to move easily but large enough that I won't be refilling it ever other week.
#1 thing I learned on TBN was to go with a plastic drum, not a steel drum (as I was originally going to do) to cut down/avoid condensation issues. I found a free 30 gallon closed top drum at a local car wash that was in really good shape. I took it home, rinsed it out the best I could then filled it completely with water and let it sit a couple days. I figured doing that would break loose anything dried inside the drum. After I drained it all out I pressure washed the interior interior of the drum to make sure it was completely cleaned out.
I looked around for pump ideas and my choices came down to the $100 pump from Harbor Freight or a $300+ pump from Northern Tool or Tractor Supply. Northern Tool did have one for around $160 but it was a made in China deal. I kept checking Ebay and I got my hands on a brand new GPI 150S-EM 12v pump for $182. While more expensive than the HF model, it's made in America and if something goes wrong with it I can buy repair parts rather than just throwing it away.
A trip to TSC for a water absorbing fuel filter and decals, a stop at Home Depot for some 3/4" galvanized pipe parts and PVC fittings and this is the end result finished today.
The pump mounts directly to the barrel in the fine thread (NPT) bung. I tried to thread the entire pump into the bung and it didn't want to go because of the weight of the pump made it difficult to get the threads started. Rather than booger up the threads I got a 2" male and 2" female PVC pipe fittings. I threaded the male fitting into the bung then threaded the female fitting on to the mount on the pump. After measuring, cutting and installing the pickup tube I dry fit it to make sure the pickup tube was a couple inches above bottom of the drum to avoid sucking up any crap that might end up on the bottom. It fit good so I glued the two PVC fittings together. It was a lot easier mounting the pump that way saving the threads in the drum. If I want to remove the pump I still can. Reinstallation shouldn't be a problem as the PVC pipe fitting threads are a lot beefier than the bung threads. I installed a spin off filter unit that has a water absorbing filter.
I wanted a method of venting the tank easily while still being able to add fuel without too much trouble. To handle that I got a 3/4" by 3" galvanized nipple and cap. I knocked out the center portion of the bung cap with the buttress threads (the course threads) and screwed the nipple in. I figured installing and removing the cap with the buttress threads would be easier and stand up better than the fine thread cap for taking the cap off and reinstalling multiple times. Before I put the nipple in I threaded the cap on as far as I could turn it by hand and marked it. Then I drilled 6 holes into the threaded part of the nipple just above the point where the cap screws all the way down to. That way to vent the tank I just unscrew the galvanized cap a couple turns to expose the holes and allow air in. After the nipple was threaded in place I mixed up some clear epoxy and filled the top of the bung cap locking the nipple in place. That way I can use the nipple as a handle that makes it easy to open and close the bung cap for adding more fuel. Here's a close up:
Made the electrical connections complete with alligator clips, put shrink tubing on all the connections, put on my decals and it was done.
I've got an extra hand truck that I'm going to strap the barrel to in order to make it easier to move around.
/ New fuel storage/dispensor #3
Good job. Similar to mine except that I have a 240 gallon cube and mine is 110. I wish I could get by on a 50 gallon drum!
/ New fuel storage/dispensor #4
Nice set up. You are going to have to be careful when the barrel is less than 25% full so the whole unit does not tip over. The weight of the filter, hose and nozzle on one side may be enough to make the unit unstable.
/ New fuel storage/dispensor #5
Looks good.
With the white plastic you will need to keep it stored out of sunlight to keep the plastic from deteriorating from UV light exposure. You might keep your eye out for a blue or black drum if you have to store it outside.
I am in the same boat as Ken and 30 gallons just barely fills the tank on one of my tractors. I bought a 100 gallon steel tank with 12v Fillrite 15GPM pump off Craigslist about 5 years ago and at the time it was good for my needs. Last year I picked up one of the plastic 275 gallon TOTETANKs (for free from a local chemical plant) and now when I order fuel delivered to my house I can get enough (200 gal) so that I don't have to pay a delivery charge.
The weight of the motor keeps it reasonably stable, but I'm planning on strapping it to a hand truck so I can move it around easier. I figured the hand truck will help stabilize it a bit.
Looks good.
I only put it outside for the photo op. It's going to live inside a storage shed on a hand truck. When I need to refuel the tractor I can move it near the door of the shed, fuel up and put it back.
Thanks for the input. Good info to keep me on my toes!
/ New fuel storage/dispensor #7
I just bought two plastic 55 gallon barrels. Only one bung each barrel with some type of cap on the other outlet. I want to set up one barrel with the pump...the other barrel used to fetch diesel then I'll transfer to the one with the pump.
I'm finding the bung has very course threads. It does has a recess in the middle of the bung that can be knock out...looks like NPT thread probably 3/4 inch. Trying to figure out what will fit in these bungs given the course threads.
Anyone with ideas?
Anyone with ideas?
The course threads are Buttress threads. I learned that online! After I found that out I looked at the cap and it even says Buttress. I also found out that there are adaptors available that thread into the course threaded bung and convert it to fine thread - NPT.
McMaster Carr carries all those adapters. McMaster-Carr
/ New fuel storage/dispensor #9
Ahhh googling buttress to npt. ..and that will work. Wish they wasn't $9+ though. Be more than the barrels in short order.
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2004 Lincoln Town Car Limousine Sedan (A61574)
2004 Lincoln Town...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
