flail vs finish mower
/ flail vs finish mower #1
mikect05
Watertown
Massey Or LS help me decide!
Hi, I have been reading up on past threads about flail mowers, some very good info, but I am getting a bit conflicting info. Some say that the flail is "almost" as good as a finish mower, and some say "as good, or better" I have several acres to mow which is mostly pretty level. Most is lawn, but I have some more rougher areas.
I just want to do all my research and get what's best now, before I buy and wish I did something else.
If the flail mower does do as good a job as a finish mower, than I think I should get that, although I tried looking at some videos, and all I see are flail mowers going very slow, do you need to go that slow?
/ flail vs finish mower #2
Flails can have different knife types/# of stations, which give you a different cut, so it depends on how it's set up.
I have both a Caroni flail (medium cut) & a 5' finish mower. The finish mower does a much better job on lawn or short grass. I run it into the field on occasion & it still does pretty well with medium-thick grass. The flail, when I've used it used on sections of the lawn, leaves lines between the knife stations & while it looks OK, it's not as good as the finish mower.
I use the flail to maintain existing fields (3 cuts a season) & it goes/cuts where the finish mower can't.
So it really depends what & how often you're mowing, but from what you describe, it sounds like the finish mower would be better.
I go slow with both & also find the finish mower much more maneuverable.
/ flail vs finish mower #3
A flail mower is no different than a rotary mower in the respect that the slower your forward speed across the ground the more times the blades are in contact with the grass in a particular area. The slower your forward travel the finer the cut. When I bought my Caroni flail I chose the 7 foot model which only uses the flail blades for regular/medium mowing and heavier brush and it does a "good" job on finished lawn. The Caroni models with the finishing flail blades were not wide enough and I want to spend as little time as possible mowing my 15 acres. Having said that the major problem with a flail mower is the same as a rotary mower and that problem is not the mower it is the tractor wheels. Any mower pulled behind a tractor is moving over grass already smushed down by the front and rear tractor wheels in rows and that is where the poor looks of a finished cut come in as a factor. A large riding lawn mower with a belly mounted mower only has to contend with grass smushed down by the small front wheels and one does not have the "row" effect caused by a tractor. Down here on the Texas Gulf Coast we have extreme high humidity most of the year and unless you mow late in the afternoons the grass is always wet and causes a poor quality finish. As it is on my property I'd rate my Rhino rotary cutter to give a "C" grade in finish cut and my 7 foot Caroni a grade of "B" for a finished cut. On the occassions we have parties or functions here on our place I use my commercial Kubota Diesel 6 foot zero turn that makes the place look like a golf course but it takes about 25% longer to mow the whole place over the larger rotary or flail mower.
PS- I would buy a Caroni 7 foot finishing mower but we have 250 Mature Pecan trees on the front of the property and there are always thousands of small dead branches in the grass. My large rotary Rhino and the Caroni flail mower do a good job of shattering the branches into small pieces but I believe a finishing mower would need the blades sharpened way too often and I am at the age that crawling under a mower 4-5 times a season to remove the blades for sharpening is just too much work.
/ flail vs finish mower #4
Hello mikect05,
Welcome to the forum,
About your needs for mowing you will have to decide what type of
cut you want and are living to live with on your sod.
What I want you to do is read the 120 plus pages of
threads and posts on flailmowers or at least some of
them to have a better understanding of how they work.
The two basic knives are the side slicer and the scoop knive
which is commonly referred to as the the duck foot kive
simply due to its appearance.
A hammer knive is typically used in a forestry mulching
flail mounted on ahigh horse power tracked carrier and
used for land clearing.
It is entirely possible to have a golf course quality of lawn cut with a
flail mower as you can mow over the grass clippings and shred them even finer.
The added benefit is you have a striper at no extra charge.
I mow mostly in a spiral pattern overlapping with my mower and a day or
two afterward there are no tread marks and no clipping left to look at
because they are shredded so finely.
I can dethatch with my flail mower as well and it has collection basket that
can carry all the clippings or thatch to be dumped later.
A finish cut flailmower with hardened side slicer knives will handle everything you
have described as long as you have the power to run one and operate it at the
540 rpm engine speed.
You also have understand that a hydrostatic transmission tractors
transmission robs power from power take off too AND IF you drive
too fast no mower is going to work well for you EVER.
Do some more reading and then come back and ask more questions
then do some more reading and ask more questions before you open
your wallet.
I hate my other rotary because it plugs up and you have clean the deck,
I do not have that problem with my flail mower.
/ flail vs finish mower #5
I personally did not care for the flail mower I had. It did cut the grass but not as well as my finish mower and was far slower. I also notice the upkeep was FAR more on the flail than the finish mower I used. Good luck on your search
/ flail vs finish mower #7
My experience is that a finishing mower will only do a excellent job on lawn that is 4" and under. It will cut taller grass but the results may not be stellar.
/ flail vs finish mower #9
A bushhog and a finishing mower are made to do two different things. A bushhog is made to mass mow down tall weeds, grass, small bushes and even small trees, sometimes on really rough terrain. A finishing mower is made for a lawn that is already manicured, not too tall and on relitively smooth ground.
/ flail vs finish mower #10
Yep - what Utopia Texas said. You can set a finish mower to cut high, and depending on the make/model will determine the height. The other thing is the spindles on a finish mower are not made to cut anything but grass. They are far from heavy duty and you risk damage trying to cut weeds,brush, etc with the finish mower.
/ flail vs finish mower #11
Just came across this thread today.
I use a Woods finishing mower to groom my 4 acre apple orchard which used to be a hay field. The finishing mower is 72" with a rear discharge which really works great. The rear discharge does not windrow the clippings but rather scatters them evenly across the ground surface. I do not mow brush with it but it will do a job on high orchard grass although you may have to go over it twice to make it look good. I normally maintain a height of about 4" and not let the grass (mixed hay grass) get above 8" before mowing it again. That way once over and it looks great. Keeping the PTO RPMs up, sharp blades and proper ground speed to match conditions will give you a very nice cut.
/ flail vs finish mower #12
A finish cut flail mower will cut as nice as a finishing rotary so you have to compare the proper machines. Flails will cut much taller grass and use less HP than a rotary. Mott used to put out a booklet called the art of flailing. A properly set up flail could be used for every mowing task on a golf course except for cutting greens. Fine cut flail mowers have been used on sod farms as well. A finish rotary will be cheaper but isn't as versatile as a flail. If all you're doing is cutting a lawn, a flail won't need much more maintenance than keeping it greased.
/ flail vs finish mower #13
Tried both. Now flailing and will not look back!
It is quieter and the flail I have gives a cut which, in my opinion is more manicured than my finish mower ever was.
The model I have has 88 knives and is designed for a fine cut.
Having said that i also have used it to clear light brush.
Just be aware that this particular mower is not intended to clear heavy brush but in a pinch will do the job,
Flail Mower, Caroni, Flail Mowers, Caroni Flail Mower | Agri Supply, 53413
/ flail vs finish mower #15
I run a 6 foot finish mower, 6 foot shredder and 7 foot flail mower with 42 HP and they all work just fine. Most mowers are set up to run at a PTO speed of 540 RPM's. If in doubt ask a local dealer.
/ flail vs finish mower #16
I am a flail owner and also run a rotary "bush hog" and have had a finish mower in the past. I could easily join the flail love fest and indeed I do think they are great mowers but in this instance I'll give my thoughts on the relative negatives. First, it is absolutely true that they require more maintenance and more expensive parts (per year) than either a finish mower or rotary. Finish mowers require blade sharpening. Rotaries require occasional blade replacement (maybe every few years if used pretty heavily in a non commercial environment). Flails, at least in my experience (rocky New England soil and used for brush clearing as well as pasture mowing) require replacement of broken clevis shackles and blades at a rate of about three to six per year at about $20 per set and 10-15 minutes per replacement. Also consider that other than blade sharpening/replacement on the rotary mower types, you usually only need to check the gearbox oil a couple times a season. On a flail you grease it (three minutes) every time you use it. Not a big deal really but definitely on the negative side of the score card vs finish or rotary.
I have very little use for a true finish mower as I am happy with the flail quality of cut in the fields I mow using flail blades that are optimized for brush. As others have pointed out, you need to specify what set up a flail has in comparing it to finish or rotary in terms of cut quality. A finish flail gives just as good a cut as a finish mower. A rough cut flail like mine gives a much better cut than a rotary but less perfect than a true finish mower unless I travel very slowly (about half typical finish mowing speed).
A positive for flails that hasn't been mentioned in this thread is the safety issue. A flail mower is inherently safer than a rotary with regard to risk of sending high speed projectiles out from under the mowers. It basically cannot happen with a flail whereas it happens all the time with bush hogs and can also happen when a finish mower hits an unseen object in the grass. Flails are much safer mowers period.
After using my flail for six or seven years, I have found myself never needing a finish mower and sometimes choosing a rotary bush hog over the flail for tough brush clearing or first spring mowing to discover new rock crops. I save on flail blade replacements by using the bush hog (with slip clutch) when blindly backing into thick brush or when there is a good chance I will hit an unseen rock. Other than those situations, I use the flail. I only do thick brush clearing mid week in the early spring or late fall when there is little chance that a thrown rock or branch will hit a human. The rest of the time I just use the flail and don't need to be concerned.
/ flail vs finish mower #17
I have a chance to buy a KUHN 6 foot. I will be running it with my l4740. 47 hp. Will I be able to mow tall grass.
2 what rpm do I run it at.
All flails I've had experience with operate at 540 PTO rpms. If your tractor has a hand throttle, set it to sufficient revs to produce 540 at the PTO. "Tall grass" depends upon your definition of tall. I've successfully mowed waist high stuff with a single pass, but it has to be dry. Taller than that and you might have to make a first pass with the mower lifted up a foot or so, then lower it to the ground for a second pass. Again, wait for dry conditions.
//greg//
/ flail vs finish mower #18
Had a Mott flail. Keeping it from vibrating, which it does when knives and associated parts get knocked off, became too onerous. I now have a Land Pride 72" finishing mower and it is better in that less work is required to keep it running. Each spring I need to make certain the spring tensioner for the deck belt is not seized otherwise kiss an expensive belt good by. Don't try to use it for a bush hog! My gear box shattered into a collection of unrepairable parts. A new gear box from Land Pride was expensive.
If your land is perfectly flat with no humps or protruding rocks the flail will do a good job but if these are not your conditions the finishing mower can cope quite a bit better.
Dave M7040
/ flail vs finish mower #19
There is one situation where my Bush Hog makes a better/cleaner cut than my flail and that is during the Winter when my 7 acres is in Winter Oats and Winter Rye. This type of ground cover is "whispy" in growth and the tractor tires lay it down as I mow forward. The flail mower cutters spin above the layed down grass and do not cut it well or at all. The next day these rows of wheat and rye where the wheels rode the day before stand back up and leave ugly strips of un cut grass which has to be gone over again or it looks terrible. The rotary type bush hog on the other hand creates a whirlwind of air under the deck and much of the strips of grass laid down by the tractor wheels is "sucked' up by the vacuum caused by the motion of the blades and then cut as usual. I will be using the bush hog in the Winter and flail mower during the warmer months. We have such mild Winters here on the Texas Gulf Coast that many still mow once a month on fields and lawns with Winter Oats and Winter Rye growing.
/ flail vs finish mower #20
Taller than that and you might have to make a first pass with the mower lifted up a foot or so, then lower it to the ground for a second pass. greg//
So what you are saying is it's ok to use the flail mower a foot or two off the ground?
The reason I ask is that I'm not done clearing the stumps, roots and limbs yet and the grass is already starting to grow and the ground is nowhere near level to cut with a mower.......
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Drop Deck Trailer (A64194)
2008 Ledwell...
1987 Kenworth T800 Day Cab (A62613)
1987 Kenworth T800...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
