ford 1700 steering column removal
/ ford 1700 steering column removal #1
cph0728
boyd tx.
1700 ford
Oil was coming out the top of the steering column. I am attempting to replace the seal at the bottom of the steering column. I have everything loose I think but the outer tube will not come up off of the steering shaft. help?
/ ford 1700 steering column removal #2
Look at the attachment below for non-power steering column for 1700. Where was the oil leaking and what seal are you attempting to replace? identify the leak location closest to associated part number for clarity.
JC,
  • STEERING COLUMN & GEARBOX, 1500 & 1700 (79_1-82).pdf
/ ford 1700 steering column removal #3
Here we go with steering column and Power Steering.
HC,
  • STEERING COLUMN & GEARBOX, W_POWER STEERING - 1500, 1700, 1900.pdf
JC,
Yes it is hydraulic fluid, my tractor is 4wd with power steering. I have it torn down to the point that I have a small space maybe half an inch betwwen the outer tube and the cove,r part 38. The tube is unscrewed from the cover but will not slide up off of the shaft. Attempting to get down to oil seal part number 40
/ ford 1700 steering column removal #5
part #47 is a big dia nut that holds the outer tube to the base/cover #38. did you loosen that? how about the two tabs in the cover? two tabs 90 degress to each other and a hole, are the tabs bolted to something to hold it steady?
jc,
can't get a photo to load, yes the big nut 47 is still on the outer tube, the outer tube is completely unscrewed from the cover. Tabs?? can't see any tabs
/ ford 1700 steering column removal #7
it appears that #46 is a bushing and has to come off before outer shaft can be withdrawn. have you take that out.
Jc,
2019 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
2006 FREIGHTLINER CST120 STAND UP SLEEPER (A67714)
2006 FREIGHTLINER...
16in. Bucket with Teeth Excavator Attachment (A68183)
16in. Bucket with...
