Quick Hitches John Deere iMatch Quick Hitch with JD Ballast Box + Extension Question
   / John Deere iMatch Quick Hitch with JD Ballast Box + Extension Question #11
I got mine the other day. It came with 1 set of bushings. TSC had the same ones but I can't put in the retaining clips on the ballast box. I'm assuming that the clips are needed, Friction wouldn't be enough to hold the bushings on the implement. ?~?~?
   / John Deere iMatch Quick Hitch with JD Ballast Box + Extension Question #12
If you are looking for a John Deere imatch one can be purchased for $350 shipped at www.muttonpower.com. I apologize if I offend anybody with this solicitation, but I didn't know where else to put this info, and it is a good deal.
   / John Deere iMatch Quick Hitch with JD Ballast Box + Extension Question #13
How much if I pick it up? Live in south bend, looking to make a skidsteer 3pt adapter with an imatch
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
