CT series dash lights
   / CT series dash lights #1
Lockport
Lockport, Manitoba
Bobcat CT235
I was parked in the sun the other day and realized that I have L,M,H and N indicator lights on the dash to indicate what range the tractor is in but I've never seen then illuminated. Do I have a disconnected wire someplace?
Thanks all.
   / CT series dash lights #2
I have a CT 235 and have never seen this lit up, in fact did not know they were even on the dash!! What year is your tractor?
Fred
   / CT series dash lights #3
Never saw any lights on the dash on mine
   / CT series dash lights #4
First light I've seen on the dash was this weekend.. I was running the brush hog, and noticed the PTO light was on. I didn't see it at first, so when I noticed it, I thought maybe so etching was wrong..
I'll look for a gear indicator next time I'm there.
   / CT series dash lights #5
First light I've seen on the dash was this weekend.. I was running the brush hog, and noticed the PTO light was on. I didn't see it at first, so when I noticed it, I thought maybe "something" was wrong.. I'll look for a gear indicator next time I'm there.
Dang iPad spelling/word choice.
Fred, it's a 2012...I think. If you take a maglight and look at the dash light position on the right top, opposite the glow plug, battery, etc on the left, you should be able to make the out. There's an L, M, H around the top and an N beneath. I looked underneath at the base of the levers for contact switches and first I thought I saw one, then I wasn't sure I wasn't mistaken. It's hard to see. If there is one it's over the hydro and if not, I'd like to get one!
   / CT series dash lights #7
Lockport;
I looked at my service manual and it shows the dash layout with three open circles on the right side and not identified. I am assuming that these dashes are stamped out and are used for many models. Other tractors using the same stamped dash layout may well have lights to signify what gear the tractor is in. Mine however does not have this although I too can see the three circles on the right side of the dash but they are not used.
It's not an issue for me as my tractor stays in the med gear 98% of the time.
Fred
   / CT series dash lights #8
Double checked last night I to have the lights but they have never lit.
   / CT series dash lights #9
Same dash panel is used in 3&400 models and Kiotis. The CT1xx & CT2xx use a switch on the treadle pedal for neutral start so no indicator switch on the range lever. Kioti and larger Bobcats use the range selector for neutral start safety, so have the indicator switch.
   / CT series dash lights #10
I'm guessing those lights, at least based on what was posted here, are not used on the open station models. My CT335 cab has those lights and just about every dash light works contingent on what's being used, e.g., pto, cruise, etc.
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
Kubota RTV-X900...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2007 FREIGHTLINER WATER TRUCK (A55745)
2007 FREIGHTLINER...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
