Best Replacement Loader Control Joystick
/ Best Replacement Loader Control Joystick #1
JackST25
Kingston, MA
AGCO ST25
My Nimco 422 loader valve has some issues and is need of repair, a loose boom spool.
I have the joystick held up with a bungee cord right now. If I take the cord off the joystick drops on its own and the boom raises.
I am considering replacing it with a brand new unit.
In your opinions who makes a better valve and why?
BRAND from surplus center, or Prince?
I also may try fixing the existing Nimco.
Thank You for the input.
Jack S.
/ Best Replacement Loader Control Joystick #2
Check your spool centering springs and the nut that keeps them tight in the cans at the bottom of the valve.
Valves by Prince or Brand will work fine.
Match your valve GPM rating to the pump GPM.
/ Best Replacement Loader Control Joystick #3
Husco is the probably the best loader valve but you will rarely find them for sale at discount houses. I installed a Prince on my Branson and while it was significantly better than the "factory" valve it still does not meter or feather very well on the dump circuit. I.e. with an over hanging load on the bucket it will runaway or free fall very easily.
I believe Husco is the factory for Kubota "B" series & possibly JD on their 3000 series.
Thanks JJ
I was able to fix the valve.
I opened up the cap on the end and the bolt came loose that holds the spool and spring together.
I was able to put it back together and it is working great!
I also had a bent stud ball on the joystick.
I was able to find the valve through Brand with the correct mounting configuration and spool pattern from prior posts on this site.
It was going to take 7 weeks to get the one I needed, but fortunately I was able to cancel the order.
My valve has no leaks also.
Roy thanks for all the info on valves.
Here are some photos
John Deere 412R (A63688)
John Deere 412R...
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
