1994 JD320 Radiator Challenges
/ 1994 JD320 Radiator Challenges #1
moresnow
Member
JD 320; Hydra lift, 48" deck
So my 1994 JD320 ran like a tank all winter and over the past few years. This spring when I opened the shed up i noticed fluid underneath the machine. I was removing the plow and checking out for fluid leaks around hoses etc I could not find anything. It is dry everywhere but when I open the radiator cap there appears to be little or nothing when i look down into the radiator? The overflow has a little at the bottom. Help thoughts? Advise?? 10351410_10203601425097247_9153770455912657418_n.jpg
The co0lant is leaking directly below the center of the drive shaft from the engine. This is right in front of the mower deck on the ground. Please anyone know what should I do. The machine runs but I wont' do this for fear of a engine failure. Is there something I should look for?
So my 1994 JD320 ran like a tank all winter and over the past few years. This spring when I opened the shed up i noticed fluid underneath the machine. I was removing the plow and checking out for fluid leaks around hoses etc I could not find anything. It is dry everywhere but when I open the radiator cap there appears to be little or nothing when i look down into the radiator? The overflow has a little at the bottom. Help thoughts? Advise??View attachment 374850
Could it be coming from the back. The front has some light moisture on the frame but not that much. I will look in more detail by getting under the machine and using a light.
Is it coming from the water pump?
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
iDrive TDS-2010H...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
KENWORTH CAB AND HOOD (A63569)
KENWORTH CAB AND...
