lenovo thinkpad t500 no boot or post code? ideas?
   / lenovo thinkpad t500 no boot or post code? ideas? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
just an old laptop at work.. the one that connects a digital console to a router.. so mildly important. I can hit a pawn shop monday and liekly find another for 100$.. but wondering if there is anything I can wave over it this weekend to make it boot.. it has a saved setup i need to copy to a board.
on button provides a lamp to the charge indicator.. but nothing else. no post codes. screen blank.. tried external monitor too.
plugged in provides the ac indicator / batt indicator lamps.. so ps is on and bat charging.
ideas?
update
plugged in, the power plug and bat light come on.
when you press the on button.. the lil lightning bolt inthe circle lights up, then momentarilly the 1 and A int he lil house looking symbols light up, then go out
no post codes on the monitor..
   / lenovo thinkpad t500 no boot or post code? ideas? #3
You might try removing the battery and replacing it...
doe is make any noise (like drive spinning up?
none i can hear.. nor do i feel a vibration. no beep codes either..
   / lenovo thinkpad t500 no boot or post code? ideas? #5
I would take the ram out and see if you can get an error code or beep while trying to boot it, if not it's probably smoked. If needed you can very likely pull the hard drive to get your files.
will do that tonight. involves removing entire bottom cover. not at all easy like and HP with lil doors and tabs with 1 screw maybee.. :)
   / lenovo thinkpad t500 no boot or post code? ideas? #7
I think the t500 ram is under the keyboard. Take out the screws with the little keyboard symbol and the keyboard should come up. I would try unplugging it, taking out the battery, and letting it sit a few minutes. From what you describe though, it sounds like it is trying to start up on a dead battery and the adapter is not powering it at all. Try it without the battery in. If you get nothing than the adapter either died, plug in the laptop is broken, etc. It should function properly with no battery and just AC power.
the lil ac plug indicator lights up when plugged in.. so it is seeing it's 20v power supply.
both with or without battery.
   / lenovo thinkpad t500 no boot or post code? ideas? #9
pull the battery ... leave it out ... plug in the AC adapter ... turn the beast on ... ( should run on AC without the battery )
if it doesn't fire up, ( no beeps etc ) then the MB /CPU is probably toast ... pull the HD and use a USB to HD cable to pull the info off the drive ....
if it seems to fire up but no screen shows , check the screen toggle button on the keyboard ... (laptop screen / remote monitor/ dual)
   / lenovo thinkpad t500 no boot or post code? ideas? #10
Pull the battery...if there is a battery on the motherboard, pull that one too.
No POST...sounds like the CMOS might be corrupted. Leave the battery out for a bit (a minute or two minimum), then replace it. If there is a motherboard battery, that's the one that needs to come out and give it a few minutes (which should reset the BIOS).
I had a similar problem (no POST or boot up) on my wife's desktop earlier this year...and pulling the MB battery for a few minutes did the trick.
Husqvarna 46in Riding mower (A56859)
Husqvarna 46in...
PALLET OF 250 TRAFFIC CONES (A58214)
PALLET OF 250...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
