Kubota BX2370 Idle too high
   / Kubota BX2370 Idle too high #1
WESTCOAST
Just bought a BX2370. The idle is at 1500rpm. The book says normal is 1350-1550. Had anyone lowered their idle or can give me a way to lower it. Thanks in advance.
   / Kubota BX2370 Idle too high #2
Why do you want to lower it? Mine is at 1400 at idle and the hydraulics are way too slow at that RPM so I don't see a need.
   / Kubota BX2370 Idle too high #3
The idle speed a tad on the high side on our BX's is a good thing.
If the idle is low you can glance at it and it appears blurry they shake so much. :)
   / Kubota BX2370 Idle too high #4
That is where mine is as well....and I thought it was pretty fast....but everyone says it is normal.
Yea you can't really do anything with the machine at that RPM but if it is just sitting while you run in the house to reload your drink you would like it a tad lower....but I guess it is what it is.
Thanks all for the insite. This is my first BX model coming from the B series.
One other issue.... my FEL is really slow. I only have 2 hrs on the machine. Will this improve or is it back to the dealer?
   / Kubota BX2370 Idle too high #6
I think the newer engines have a higher idle speed due to latest tier of emissions and the book was not updated.
David Kb7uns
   / Kubota BX2370 Idle too high #7
Where are you setting the rpm's when working the loader? The BX's need to be in the upper rpm's to operate well. I run mine at minimum 27-2800 rpm's for when using the loader.
   / Kubota BX2370 Idle too high #8
I am usually around 2500rpm for loader or BH work.
2016 John Deere 6110M Utility Tractor (A50657)
2016 John Deere...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
2009 MACK CXU613 DAYCAB (A50854)
2009 MACK CXU613...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
