3 Pt. Backhoe
   / 3 Pt. Backhoe #1
rockarosa
Warren Ridge, Ohio
Mahindra 4550
Does anyone on here have a New Holland T C 30 with a 3 Pt backhoe? Just wondered if it works well for you.
   / 3 Pt. Backhoe #2
As in After Market with No Sub-Frame ?? I have a TC 30 with the Sub-frame mounted 757 B.H. .
Fred H.
   / 3 Pt. Backhoe
Yes Fred, I bought a 3 pt. from Liberty Implements a 6 ft one. They tell me that I don't need a subframe but I'm a little concerned after reading some posts on here. How does your Hoe work out for you?
   / 3 Pt. Backhoe
A bolt on frame that runs from the back of the tractor up to the loader to keep the stress off the 3 pt.
   / 3 Pt. Backhoe #6
   / 3 Pt. Backhoe
Well, I decided to play it safe. Bought a slightly used NH subframe for $250. I should be able to figure out a way to mount the Liberty backhoe with it.
   / 3 Pt. Backhoe #9
My Sub-frame mount 757 works Great . I to use to be concerned with the issue's people were having with cracked housing's , etc... . Question's I had for them were not answered to my knowledge , Like was it a Geared model or HST model . One area I Think may cause problems with either is How tight people bring up the top link . With My 757 , I Barely put down pressure on the ground using the B.H. bucket and snug up the top link . You can keep putting more and more pressure on the ground and keep tightening up the top link , but I think that is were problems occur as it puts a " Bind " into the 3 point and the tractor housing itself .
I know I read those threads before about people having issue's , Just My opinion on what happened , also , these are compact tractors and Back hoe's , Not full size back hoe's or Excavators , Thus I error to the side of taking my time and not over loading things.
Fred H.
   / 3 Pt. Backhoe
Fred, I didn't want to take a chance when I can go ahead and put a sub frame on. I don't know how different a Liberty backhoe is compared to the NH. It probably won't just bolt up but I should be able to figure something out.
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
METAL BOLT BINS (A58374)
METAL BOLT BINS...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2013 International WorkStar 7400 Altec D3060ATR Insulated Digger Derrick Truck (A55973)
2013 International...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
Forklift Safety Basket (A56857)
Forklift Safety...
