JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,976
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
This is a near-new tractor hours-wise. An April 2011 purchase with around 165 hrs. now. Sat over the winter only started and ran some once a month. In Nov. 2013 the lift was used with no problem with a roughly 2500lb object (boom cutter) mounted. Had been used all summer. In early April 2014 the 3pt lift would not make the usual noises at "constant pumping" (fully up) levels and would not put tension on the linkages. Removed the boom cutter, moved the tractor and found the lift would then go up and down. Attached 1400lb 7ft bush hog and found the lift would only raise the front half of the hog. Would not raise the full hog weight. [An hydraulic top link was used to raise the rear after the 3pt raised the front -- then the whole hog slowly went down to the ground.Would not stay up.] So in effect the 3pt lift has become disabled.
Some suggest the control valve inside the pump is stuck. Some theorize a split line inside the tractor housing or else a busted seal in the lift cylinder. Note: All that is internal to the heavy tractor housing and thus any leaks go right back to the sump.
One more clue: The front end loader and other remote hyd devices work fine UNTIL the combining valve is engaged [whose purpose is to add 3pt pump flow to the total remotes flow.] Once the combinging valve is engaged, the FEL goes dead and nothing works via the remotes.
The tractor is waiting inline at the nearest dealer for serious investigation. Dealer mechanic has already been to the farm and verified there IS a problem.
Anyone out there had this happen before ?
