New owner of CK20
   / New owner of CK20 #1
bjon79
Mehoopany, PA
Kioti CK20
Hi
I am glad to have found this forum. Just got a new CK20. I am happy with it but not so happy with the dealer. Ato center top mount of hitch.
after 1 hr of test mow I had lost the pin that holds the finish mower on. Found it and put it back in place. Next day lost another pin. Looked for it but instead found a bolt I did not know I had lost. Put bolt back on mower, used spare parts pin and clip and mowed another 19 hrs with only one more problem. The front tire had a 3 inch split between the tread bars. Dealer said I abused the tire by driving on rocks????
Still waiting for a new tire from North Carolina as well as the back blade to be delivered.
Can I put a Brush Hog from a Ford 8N on my CK20?
John
   / New owner of CK20 #2
How big is the Bush hog and is it set up for a 3 point hitch. A 4 foot bush hog would be the optimal size for the CK 20 A 5 footer would be quite large and very heavy you would need counterweight on the front assuming it's a three point mount and would be lacking a bit of power. Anything larger would not be recommended.
   / New owner of CK20
It Is 5 ft and set for 3 pt hitch Thanks for info. I have a front end loader to counter weigh it but perhaps I will look for a 4 footer.
Thanks
   / New owner of CK20 #5
Give the five footer a try and see how you like it all depends on what you're cutting and how fast you want to go I think u would probably be happier with a four though
   / New owner of CK20 #6
Welcome to TractorByNet!
I moved your thread to the Kioti Owning & Operating forum. :)
   / New owner of CK20 #7
A CK20 will handle anything that an 8n will - the FEL will give enough counterweight even when bucket is empty - the 2 are close in weight and horsepower - if it's a CK20HST then the Kioti wins hands down - and remember the CK20 is rated at 1305 lbs. on the 3-point :2cents:
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
