Good morning!!!!
/ Good morning!!!! #21,501
This becoming scary. From the National Weather Service for an area not too far from me.
...Record high minimum temperature tied at Death Valley CA this morning...
The morning low of 83 degrees at Death Valley tied the record for the warmest low on this date since 83 degrees was measured in 1918.
Looks like its going to be one hot summer.
/ Good morning!!!! #21,502
70f and no rain last 24hrs, sun shining brightly
Great day yesterday, last piece piece of roof tin fitting and placed, even got some mowing done.
Hope today to get a load of concrete to finish off the driveway, get some more roofing screws in place, mow a bit more.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
/ Good morning!!!!
Wow. We haven't seen 70 so far..... I understand the west is in drought, so high temps don't help that. Might be a tough year in California.
/ Good morning!!!! #21,504
Hit 74 here one time north of Lansing this spring....
/ Good morning!!!! #21,506
Did you see this long-range temperature forecast from weather.com?
West Coast Roast, above average in Texas and Maine. Cooler everywhere else. I always take these long-range forecasts with a large grain of salt. We'll see.
We did make it to 60*F, with cloud cover all day.
/ Good morning!!!!
Made it to 55 today, pretty windy tho. Going to check on the critters in a bit.
/ Good morning!!!! #21,508
Has been 62 here today for a while, spend much of the day cleaning up still MORE of that storm debris from last December....I am only about 80% done. Probably not going to have a garden this year because of the delay.
/ Good morning!!!! #21,509
Good Afternoon. 1705, sunny, 90F with 43% humidity. Forecast high of 91F this afternoon, and a low of 59F tonight.
I worked in the garden this morning. Got the whole thing plowed, watered the peppers and tomatoes and did a little hoeing in the squash. I need to side dress everything, but I have to work in the office a couple of days this week, so not sure when I'll get it done.
Larro
/ Good morning!!!! #21,510
Gorgeous day, in the 70's
7 yds of concrete to do the job. Someone else cancelled so we got delivery about 11AM
/ Good morning!!!! #21,511
2014-05-06, 0334
35 right now (bit chillier then yesterday) and a high of 58 predicted.
/ Good morning!!!! #21,512
38 degrees and will reach into the low 60's today.
Off to Mass today for a trade show means standing around all day!
/ Good morning!!!! #21,513
51 this morning high of 77 later today with scattered storms. Took two additional bathes yesterday in quick hitting t-storms. Hopefully today will be better
/ Good morning!!!! #21,514
A cloudy 53 with 70 and a chance for more rain. Fortunately only a small shower yesterday.
Whippoorwill singing at the top of his lungs on our roof this morning before light.
/ Good morning!!!! #21,515
Coffee pot is brewing. 33° with clear skies this morning. Heading to 63° with clear skies all day . Going to give cutting the lawn a try today. Had to order a new tires for lawnmower. $50 for a 9" tire from JD.:( Should be able get lawn done by filling tire before starting. Must be my year for tires. Car has a slow leak on one of it's front tires.
Erv, AccuWeather shows that Howell has had 4 plus 70° days this year. All in April. They probably happened while we were sleeping. :D
Good Morning All.
/ Good morning!!!! #21,516
Just curious, what does concrete cost per yard there? I know many things are much more expensive in Hawaii because they have to be "imported".
/ Good morning!!!! #21,517
I spent all weekend pulling soaking wet carpet & pad out of the basement, and I did get the woodstove lit to help with the drying out process.
I got almost all the furniture back in, some is in the attic, and I is mostly dry. I need to get the TV set up for this weekend with the girls at a minimum.
Looks like I've got plenty of time to finish, yesterday my Boss laid me off. I'm on Payroll until the end of the month but I need a new job ASAP it seems.
Be well all,
David
/ Good morning!!!! #21,518
David, I am sincerely sorry about your job situation...you don't deserve to deal with that atop everything else.
/ Good morning!!!! #21,520
Morning all, 39F this fine morning predicted high of 61F. Don't get sick very often but caught a cold with a cough, hate not feeling right.
2014 Freightliner Cascadia 125 S/A Day Cab Truck Tractor (A59230)
2014 Freightliner...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2012 International Prostar (A61306)
2012 International...
Deere 410L (A53317)
Deere 410L (A53317)
2017 FREIGHTLINER CASCADIA SLEEPER (A59905)
2017 FREIGHTLINER...
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
