Hydr. Supply for the Feeder on my wood chipper always return to neutral
   / Hydr. Supply for the Feeder on my wood chipper always return to neutral #1
Gaetan B
Quebec, Canada
John Deere 5075M, JD RU 2010
I have a 5075 M with rear Deluxe 3 valves hydraulics. When I operate my Wood Chipper even if I select the rotating knob to hydr. motor and use the valve with the flow control I cannot keep the valve in working position. The handle always return to neutral :mad: I have tried to open the flow control to max as the Frontier WC already have one...
Any suggestions!
Any suggestions!
I should add that I am talking about the oil supply of the hydraulic feeder as the chipper cutter is working out of the PTO. The tractor is a John Deere. As the oil gets warmer it tends not to hold in working position and return to neutral faster and for no apparent raisons. I am suspecting over pressure of the return line...anybody has gone through this?
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
2012 Cadillac SRX SUV (A55758)
2012 Cadillac SRX...
2006 Nissan Titan Crew Cab Pickup Truck (A55788)
2006 Nissan Titan...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
