My new Racor install
   / My new Racor install #11
Any pics to show new location? My 225HP 4 stroke Yamaha marine outboard has a similar setup, and the filter is after the tank and prior to any pumps, FWIW. And the outboard engine manufacturers are adamant about not having any flow restrictions to the engine. Granted it's gas vs. diesel, but it's still all about keeping water and particulate matter out.:thumbsup:
I need to get a couple of pics but its similar to Scoobys photos. I do have my filter plumbed before any of the pumps.
   / My new Racor install #13
Here are a couple of pics of my Racor fuel filter install on my BX2350.
<Snip>
The bad part of my install is that the new filter is after the pump. In theory this can stir the water and fuel up and not allow the water to separate as well. The good is...
I'm confused, did you move the new Racor in your later install to before the pumps, but after the fuel tank? If so, I missed where you might have said so?:confused2:
   / My new Racor install #14
Too bad your original location didnt work. I see it now that yours was too close to the axle. I should have mentioned it. When I did mine, I was shooting to get it as close as possible to the operators station floorboards.
Now that its squared away, enjoy your filter:thumbsup:
   / My new Racor install #15
I'm reviving my old thread. My original install was not good I had to change it. The problem didn't pop up until I mowed with it. The wheel turned all the way to the left was hitting the filter. On flat ground it wasn't a problem but it the front axle was tipped up at all it hit. It actually unscrewed the filter and dumped fuel all over the yard.
In an above post Waxman suggested moving it back to the FEL bolts. I loved the idea and did it. Guess what, the tire hit it there also. I ended up using the original bracket and added to more that extended up a few inches and bolted the Racor setup to that. If you look at Scooby074 pics its in a similar location but mine is mounted higher. It seems like looking at Scobby's photo I had mine in the same place the second time around and my tire hit it but maybe his is a little higher or tucked in tighter than I had mine.
I think you just solved a mystery for me. I also did a Racor install similar to Scooby's. When I settled on the placement using the FEL bolts, I checked to ensure the tire wasn't hitting it. Looked good in my garage when the install was complete. Not a week later I see the filter pushed upward and the bolts bent up. Couldn't figure out what happened. Now I think I know. Must have hit the tire when the left tire was pivoted up in full left turn. Right now it's being held by two zip ties until I can re-make the bracket. Going to go higher and further back toward the FEL mounts this time. I'm lucky nothing but the bolts broke/bent. Thanks for posting your issue.
Here's a pic of the initial installation.
Scooby, it didn't seem to mater where I mounted it in that area, the tire was going to hit it. I'm sure you tire comes close to where yours is. I would check mine and the tire wouldn't hit it but when I actually started mowing with it rubbing occurred.
As far where the pump is mounted before or after the fuel pump, it has more to do with how the fuel lines are routed than the physical location. I have fuel lines running forward and then back again to make it so its plumbed before the fuel pump. Its a lot of extra fuel line but it seems to work fine.
CHDinCT, that looks similar to my second try. My tire was hitting the black drain valve on the bottom of the Racor. My bracket isn't as well made so it just bent quite a bit but I also feel lucky I didn't break the Racor mount. When mowing you end up turning hard a lot and the tractor is moving around a lot and it ends up being a lot different than when testing it out on flat ground.
   / My new Racor install #18
Dave, mines in there as tight as possible to the loader mounts/floorboards.
Ive tested it at full lock and with the wheel as elevated as possible (driven up a car ramp) with no contact. I havent come close to the filter yet, with lots of mowing and about 30h of use, but you got me a bit worried lol. Im going to really try to make it contact now!!
   / My new Racor install #19
What I've been trying to understand is whether your fuel filter/Raycor unit is plumbed between the tank and where the fuel pumps are; not so much as where the filter is physically located on the tractor's chassis/frame. This is because of what you mentioned about the pump(s) possibly agitating the fuel before the Raycor could filter out the maximum amount of water and particles, if the fuel was being pushed vs. being pulled through the filter. It would seem you have added fuel line length to allow the pump(s) to pull the fuel toward the injection pump and away from the fuel tank, correct?
I'll explain how it's plumbed and that should answer the question. From the factory a few inches from the fuel tank there is the small filter and then the factory lift pump which is about the size of a fuel filter. I removed the rear filter and ran fuel line up to the inlet of the Racor then the outlet of the Racor back to the inlet side of the lift pump. This plumbs the Racor before the small lift pump. The lift pump then leads to another small factory filter and then the main injection pump.
2020 Ford F-150 Crew Cab Pickup Truck (A55788)
2020 Ford F-150...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
