2000 or 2001 Chevy 2500
/ 2000 or 2001 Chevy 2500 #1
davkir
Gold Member
Hendricks Co., In
JD 2305 W/CC & R4
We just bought a Chevy 2500 Silverado. The title and vin# verify it is a 2000. However it has the 6L gas engine and torsion bar suspension. Some of the parts I needed for it had to come from a 2001.
The GVWR /tire tag is dated 3/00. No owners manual.
I want to get a gooseneck hitch for it but I'm now not sure what model year it actually is.
Anyone have any information about how to tell them apart or the difference between a 2500 and a 2500HD?
Thanks
/ 2000 or 2001 Chevy 2500 #2
As a rule the model year switches in August, or four months before the calendar year changes. That should make your truck a 2000. This is just a rough guide though a sometimes model years will be different.
/ 2000 or 2001 Chevy 2500 #3
If it has 2001 chassis components go with a 01 MY.
This must be a GM thing. I ran into this with a 07 GMC 3500. That year they had the classic and new body. Parts were tricky.
Chris
/ 2000 or 2001 Chevy 2500 #4
8600 GVW for 2500 on door sticker.
HD I think is 9200
/ 2000 or 2001 Chevy 2500 #5
In 2001 Chevy renamed the 2500 the 1500HD and introduced the 2500HD to replace the old body style 2500 (5.7L & 7.4L engines).
Go by the 10th digit of your VIN number to be sure of your year ("Y" would be 2000 and "1" would be 2001).
/ 2000 or 2001 Chevy 2500 #7
Not all. Some HD's were 8800# GVWR. Chris
I just dug out the 2001 Silverado brochure and according to that, there was a 2500 model made for the 2001 model year. It was available in a regular cab long box and an extended cab short bed. GVW was 8600.
All 2500HD models from that year had a GVW of 9200 and all 3500 models had a GVW of 11,400.
/ 2000 or 2001 Chevy 2500 #8
Maybe different years. I know on my 05 Dmax the GVWR was 9900# because it was a 3500 SRW but the same truck in a 2500 was 8800#.
Both a far cry from my Fords. My 04 F250 was 10,000# gvwr while my 06 F350 SRW is 11,500#.
Chris
Chris
This truck is a 4wd extended cab with an 8' bed. GVWR 8600#
Thanks for all the information.
/ 2000 or 2001 Chevy 2500 #10
Thanks
Rebuilt total loss?
/ 2000 or 2001 Chevy 2500 #11
I know GM once in awhile does some strange things. I bought my 99 Silverado 1500 new. It was ordered the last day you could order a 99. I had to replace the u-joints on it. If I buy off the shelf u-joints they are too small. I have to buy u-joints for a 2500 Suburban. I also had to replace the front pinion seal (who knew you would damage the seal setting the front of the truck on the drive shaft and spinning the tire - lol). A standard seal didn't fit. I forget what it was for, but mine was probably a 3/4 inch bigger. Same with brakes.
2008 New Holland T2420 (A62177)
2008 New Holland...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2007 International 4400 S/A Dump Truck (A61573)
2007 International...
