Oil & Fuel Revved up then stopped, won't restart
   / Revved up then stopped, won't restart #1
Rushford, NY
30 hp Bobcat
Ct-230 Mowing along, reved up I shut off asap,, wont restart... Tried Fuel filter, New Elect Shut off, Seat switch works fine. No fuel to injector lines.....
   / Revved up then stopped, won't restart #2
Oh-OH, that is the "classic" symptom of gears stripped off in the injection pump. What year build is it, and how many hours on it?
2009 Ct 230 appx 1450 hours. Hydro, Really just been a trouble free workhorse till now... Thank you for response
   / Revved up then stopped, won't restart #5
2009 year should have been past that problem unless it is very early 09. Daedong changed suppliers of the gear sets in Fall 2008. Most of those failures I have heard of happened around the 500 hr. mark. Before diving into the injection pump verify you are getting fuel pressure (not just flow) to the injection pump. Take feed hose off from filter to injection pump and connect it to a small pressure gauge and crank the engine. Good fuel supply/lift pump should be pushing about 7 psi.
If you do need to go into injection, or replace it, post question in the Kioti forum you have same as CK30. A couple guys that frequent that forum are very good at explaining removal and disassembly.
   / Revved up then stopped, won't restart #6
Check with your dealer. Just replaced mine (injection pump stuck in closed position) under warranty 2009 model. My dealer told me the injection pump fell under a 5 year emissions warranty. What ever way you go, the pump is cheaper through Bobcat aprox. $800. Good luck.
   / Revved up then stopped, won't restart #7
Make sure your foot pedal is in the neutral position, otherwise it won't start.
If you read the forums regularly, or historically; there's a lot of mention that the Bobcat CT series foot pedal has a tendency to stick in position. Normally not enough of a problem for many people to fix as you just push the pedal in the other direction to stop the creep. But it does make a difference if you shut off the tractor while it's in that position. I must have spent 30 to 60 minutes troubleshooting the electrical and fuses before I realized that the pedal acts as a neutral safety switch preventing starting "in gear".
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 Freightliner M2 106 Bucket Truck (A55852)
2012 Freightliner...
