2wd front axle retrofit on Beaver?
/ 2wd front axle retrofit on Beaver? #11
I'm not sure having a wider front stance will help you much since the axle pivots. Others can speak better on that subject.
It will help a little. If you made the front axle 10' wide, even though it pivots, it would take a lot more to roll the machine vs. the normal axle, so any increase in width helps at least some.
/ 2wd front axle retrofit on Beaver? #12
Techwrtr2, True that the front wont really affect stability, just nicer to have it match the rear stance, as for rear weight, I agree 100%, this thing has way too much torque for it weight. I don't want to fill the tires as I have a generally soft land and will be using it to cut the grass... I would rather invest in some removable wheel weights that I can put on in the winter
I mow with filled tires, I tend to spin less. Where I mow however has a very high clay content so ruts really aren't an issue.
/ 2wd front axle retrofit on Beaver? #13
This guy figured it out on his Beaver!
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A59230)
2007 Oshkosh...
