Buying Advice Is pt425 a good option for dragging brush
   / Is pt425 a good option for dragging brush
I have an avant 420 coming on Friday so I can demo it. I have only seen pictures and videos of it so far. Still want to see the power trac since I can buy two 425s with an attachment for each for the price of the avant. I will be loading a trailer and rear loading the trucks with the logs so the 425s lift height should be fine. Our trucks have the enclosed chip bodies so log loading is limited. If anyone within a couple hours of Ann Arbor Mi has a power trac I could look at in person I could buy lunch. Thanks again for everyone's input
   / Is pt425 a good option for dragging brush #32
Please share some pics and your impressions of the Avant 420…
   / Is pt425 a good option for dragging brush #34
Yes, please share regarding the Avant. I'm going to look at one soon. Just got back from Tazwell where I demoed the PT 425 and 1430. But that's another post.
On YouTube videos, the 420 looks WAY under powered for hilly terrian (would barely climb over one small hill in the video). However, the 428 looks nice. But now we're up to almost $30K (saw last year's model advertised for $28K on Machinery Trader). Is it worth twice the price of a similar sized PT? If there was a dealer close by, then maybe. As it is, my closest dealer is 150 miles away. Still, that much closer than PT.
   / Is pt425 a good option for dragging brush #35
I have an older Power-Trac 422 with over 2500 hours. It has the body like a newer 425 with the engine of a 422. The tractor weighs in at about 1200 Lbs + attachment. It is neither extreamly heavy nor overly light and is easily moved on a tilt-bed, one-ton, trailer.
I use the grapple bucket with the short teeth for my brush moving needs. It is the envy of the neighborhood as it can move between 800 and 1000 Lbs in a single grab. (I have added weight to the back and made a few modifications to stiffen the lift arms.) The hydraulics have more than engough power as designed.
My local tree service has a large chipper. We used it to fill their two axel truck 4 times in one 7-hour day moving the brush with my Power-Trac. I would use the bucket to smash down a pile, grab it and swing one end into the chipper. Drop it, then get around the end and shove it in. Very little hand work was required.
Their guy remarked, "We gotta get one of these!", as it was his job to move the brush by hand. He had an easy day running the chipper and only handling a few scraps. We even picked up a few larger pieces up to 16" by the end of the log and just shoved them in.
Before modification (as from the factory) the PT could easily lift an 18" oak log 6 feet long and carry it, at will, up and down my back hill which is 23 degrees steep (not 23% grade).
If I had one complaint, I broke the bucket tilt mechanism when I was ramming it into 8" stumps to push them from the ground. (I stiffened the lift arms when I fixed the tilt.) This was the only "weak" part of the design and I only broke it with what could be termed serious abuse.
The attachments are wonderfull and change quickly....un-powered attachment change in 10 seconds without leaving the seat....powered attachment change in less than a minute because I have to get off the seat to snap the hydraulic quick-connects.
Lift hieght of the Avant is much higher, but the PT can place most things tailgate high on my lifted Dodge.
I also like that most attachments are welded 1/4 inch (or more) plate steel and not stamped.
For those without a big budget, they also advertise used PTs...I bought mine this way.
Is it perfec, no. Is it pretty darned useful...Oh yeah!
Don't judge the machine by their videos. They are in a word...Lame! I work it far harder and it is much more capable than shown.
   / Is pt425 a good option for dragging brush #36
I showed some of those videos to my wife, she said they should get somebody that's used a PT to do the demonstrations.:laughing:
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
15" Concrete Pipe (A53316)
15" Concrete Pipe...
2019 CATERPILLAR 336GC EXCAVATOR (A52706)
2019 CATERPILLAR...
