Quick Hitches NEW Style QUICK HITCH Found on Craig's List
   / NEW Style QUICK HITCH Found on Craig's List #1
PhysAssist
Elite Member
Upstate NY- see the BIG lake- look just below it..
Kubota B2320
Tractor Owners! Let us make your lives easier!
I found the above listing on local CL search for "3-point", it looks like a good idea, but someone who wants it could easily make their own, if they can weld, cut, and drill.
Also the text references an unlocking handlle on thr male component, but I don't see one there at all.
   / NEW Style QUICK HITCH Found on Craig's List #2
Man that seems nice but I really wouldn't want to see how much it costs! That can't be cheep I can just imagine having to buy the bracket for each piece of equipment wow!
   / NEW Style QUICK HITCH Found on Craig's List #3
I like that idea.:thumbsup:
Gonna cost more, since you need the female piece for each attachment. But it is nice since the female piece can be made to fit more implements instead of making everything QH compatible. Especially when you like used older equipment like I do. And certainly looks easier to hook and unhook than a QH. I think there is a little more room for error when backing up. You dont have to be perfect:thumbsup:
   / NEW Style QUICK HITCH Found on Craig's List #4
Yea its a great idea but it will cost a lot more to make that female piece than it does to make older equipment QH compatible! Probably a lot harder too.
   / NEW Style QUICK HITCH Found on Craig's List #5
Basically the same thing as a delta hook hitch system.
   / NEW Style QUICK HITCH Found on Craig's List #6
   / NEW Style QUICK HITCH Found on Craig's List #7
Yep I agree, couldn't think of the name of the other one, Delta Hook.
   / NEW Style QUICK HITCH Found on Craig's List #8
Not sure if it would be harder or cost more money than just making the female piece fit the implement? I am assuming DIY here and not ordering from them.
But some of my stuff, the lower links are spaced TOO far apart, and the distance from lower pins to toplink is wrong also. Neither of those are changed easily.
But a few pieces of the channel they use for the female part, I think I could make that fit quicker than modifying an implement. I could be wrong though. Probably would just depend on the implement. Some may be easier to convert to QH, others may be easier to make the female part for.
   / NEW Style QUICK HITCH Found on Craig's List #9
I had one piece of equipment that was to wide also, all I did was to turn the two lower links in instead of out and it worker great. Now it isn't always that easy, it's just like you said it just depends on the piece of equipment.
   / NEW Style QUICK HITCH Found on Craig's List #10
There are two spring loaded pins on the male componet with a cord you pull from the seat to activate.
Here is a video.
Jiffy Hitch - YouTube
Their website is down or something as I can't get it to load.
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2010 Ford Crown Victoria Sedan (A55853)
2010 Ford Crown...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
2014 GENIE S-45 MANLIFT (A52707)
2014 GENIE S-45...
2007 Toyota Corolla LE Sedan (A55853)
2007 Toyota...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
