Kioti hydraulic fittings are what type?
   / Kioti hydraulic fittings are what type? #11
Because the standard tractor cannot do what I need it to do and I need to add hydraulics to it.
Are you asking what the remote hydraulic connectors on the back of the tractor are?
If so they are standard "Ag" 1/2 inch also know as ISO 5675
   / Kioti hydraulic fittings are what type? #12
I like to learn if a machine can do what I need a machine to do before I spend money on a machine rather than buying a machine and hoping to God that it all works out. For reasons I don't apprehend, some people believe that planning is putting the cart before the horse.
"God" has nothing to do with machine choices and whether it might all work out. Before you can apprehend the reasons you might first have to comprehend them!:confused2:
Do what I did; get the Kioti dual remotes at the dealer, then a diverter valve from Brian at Fit Rite, and you can run a hoe, grapple and snowplow with crossover valve. Everything works perfectly, oh yeah I also have Brian's Top-N-Tilt kit too for remote adjustment of my BoxBlade and Igland 4001 Series Logging Winch. AND, I have a welded on thumb kit on my Kioti hoe, and a joystick with trigger that replaces the loader control factory knob for use on my grapple and plow.
That might be too much advance planning for some to comprehend though...:dance1:
So that I know, why the negative attitude toward my person?
   / Kioti hydraulic fittings are what type? #14
Of course you don,t come across that way,somewhat brash.Maybe you should go back a few posts and reflect a little?Just saying.
Of course you don,t come across that way,somewhat brash.Maybe you should go back a few posts and reflect a little.Just saying.
And you, pillier-on, exactly what is my offense?
   / Kioti hydraulic fittings are what type? #16
Not trying to pile on but some of your replies have been somewhat sarcastic in nature.No offense taken.Very sorry,did not mean to hurt your feelings
Not trying to pile on but some of your replies have been somewhat sarcastic in nature.No offense taken.Did not mean to hurt your feelings
Excuse me?
Thanks.
Same at the loader valve block and power beyond port?
As sharp as you are you will be able to figure it out.Take care.
I am figuring it out right now.
I've said nothing against your person but you've followed me around a bit on these forums making barbs at my person.
2020 ATOKA TRAILER & MFG. 40+5 LOADER TRAILER (A58214)
2020 ATOKA TRAILER...
8" Wilton Vise (VISE ONLY) (A59076)
8" Wilton Vise...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
LOT: Misc. Oils, Coolants, Tires (MOST OPENED OR PARTIALLY USED) (A59076)
LOT: Misc. Oils...
New/Unused 8 Piece CFG Industrial Mini Excavator Attachment Set (A57454)
New/Unused 8 Piece...
