New Mower Recommendations
/ New Mower Recommendations #1
8N Ren
Gold Member
Manitoba, Canada
8N Ford
Hey folks,
I'm in the market for a new push mower this year, as my old one bit the dust last fall.
Our wants are, around 22" cutting width, has to be self propelled, with perhaps electric start. I'd like to be able to have the option of side discharge and rear bag collection for when we mow in different areas of our yard.
We would really like to get a Honda, we have a tiller by them and that thing rocks. They make a great engine. The only problem is they are all rear discharge unless you go with a small push mower from what Ive seen on line, I haven't gone to the dealer yet.
I'm open to any and all brands though. The yard area isn't quite a half acre, this will be for the areas where the lawn tractor can't go, between trees etc. My budget is $1000 or so. Help me spend my money!!
Thanks
Forgot to add that the yard site is flat but is bumpy in spots.
/ New Mower Recommendations #2
Several companies make self propelled mowers with the rear bag/side discharge option, then put Honda engines on them. The first that comes to mind is Craftsman, but I've seen others, their names just escape me right now.
/ New Mower Recommendations #3
I have a Craftsman side discharge with rear bagger but it has a Briggs and Stratton engine. I have had it for many years and it still starts on the second or third pull (no battery start on mine nor is it self propelled). It sat under my patio for 3 years with fuel tank empty. Last fall I cleaned it up, change oil, cleaned air filter of dirt dauber nest, put in fresh fuel and it cranked right up. I used it for a while picking up leaves then decided to get a lawn sweeper for that. It sat all winter with fuel in the tank till last week, I needed to pick up some sweetgum balls that had fallen in a narrow spot between my shop and a fence. I took out the old mower with last falls gas, second pull it fired right up and it sucked up all the balls for me. Now it is parked back in its storage spot. I think I will remove all the old gas now as I don't plan to use it again for a while. It is and has been a good push mower. I do think that Craftsman (MTD Mfg) has a self-propelled one and even one with electric start that would be well within your budget. Almost all small mowers now are made by MTD regardless of brand name.
/ New Mower Recommendations #4
Gary - it does seem that the vast majority of "push" mowers are made by MTD, they've just about covered the tiller and mower bracket with numerous name brand badges slapped on their products.
I just looked through their site and it seems that they have several that come in two flavors, one with a Briggs, then the same with a Honda engine, with the Honda powered one usually about $50 more.
I like the newer Briggs (OHV models) a lot more than the older ones, but based on my luck with Honda engines, I'd gladly spend the extra $50 for the upgrade.
Wow 3 weeks and 240 some views and that's all the responses? Gee whiz guys thanks for the help.
Anyhow I went with a Toro.
/ New Mower Recommendations #6
Why would I comment on a 21" mower when I haven't used one in at least 40 years, or ever owned one? Take your attitude and go use your Toro.
/ New Mower Recommendations #7
Well, if you got a Toro, then what you really got was an MTD. I mentioned that MTD had most of the small mower production and that they came with both Honda and Briggs, and that several flavors of those came with side discharge and a bagging system.
The 5 year full coverage warranty as well as 5 year guaranteed to start or fixed for free was the deciding factor. Not to mention it had all the features I wanted.
Why are you commenting then?
LOL! Don't get stressed man.
/ New Mower Recommendations #12
I have Toro Timemaster 30" wide cut with electric start. It has side discharge chute capability. It also has rear bagger and also mulching capability built in, too. I use the side discharge chute in the spring when the grass is thick and growing fast. Your initial post stated 21" wide cut, but you owe it to yourself to Google search "toro time master forum" to see what others are saying pro and con. It sells in the $1000 range and has a Briggs & Stratton engine.
/ New Mower Recommendations #13
MTD supplies a lot a brands, but Toro isn't one of them. I get frustrated at times on sites like this with all of the so called "experts".
I have a Toro and a Honda. Both good mowers, but I prefer my Toro super recycler.
I got the super recycler but there's still snow on the ground here so no chance of trying it out for awhile. I would have gone with the time master but we have some nice trees and that beast won't fit between them.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2023 Dodge Ram (A66408)
2023 Dodge Ram...
