3-Point Hitch Quick Hitch too narrow.
/ Quick Hitch too narrow. #1
splotkin
Member
Western Ma
Kubota BX1850
I just purchased a Harbor Freight Cat 1 Quick hitch. The bottom spread is 27 inches and my Country Line 60 inch rear blade is about 27 3/8 inches wide. It will not fit the quick hitch. According to the quick hitch manual the spread should be 27 1/2 inches. Has any-one else seen this? I am bringing the quick hitch back and will have some-one measure the spread on another one to see if the hitch is out of spec or if all of them are too narrow.
/ Quick Hitch too narrow. #2
I am guessing a hydraulic jack and a piece of 4x4 would fix it pretty quick, don't you think? Just spread it out a bit over the desired spacing and it will spring back to where you want it.
/ Quick Hitch too narrow. #3
I have a harbor freight quick hitch I can measure tomorrow.
/ Quick Hitch too narrow. #6
Sounds like the implement is a bit too wide, too.
ASAE standard for quick hitch inside width:
ASAE standard for implement width:
Bruce
/ Quick Hitch too narrow. #7
My harbor freight quick hitch is 26.5".
/ Quick Hitch too narrow. #8
My Harbor Freight QH went back to the store. Too many problems to solve and I was going to have to replace the pto shaft on my chipper. I got a different type and problems solved.
Lots of luck
/ Quick Hitch too narrow. #9
I have a speeco and its a bit too narrow-- maybe right on the narrow end of the spec or a bit under. Wish I'd returned it.
/ Quick Hitch too narrow. #10
I had the same issue with mine, and thought it was just the implement, on old York rake. I've had it too long to return... But it was definitely too narrow..
/ Quick Hitch too narrow. #11
Harbor freight made 2 cat 1 quick hitches. The one was narrow.
/ Quick Hitch too narrow. #13
The problem is that the attachment dimensions are all over the map.
I have four Category 1 attachments for my B7500. The inside width ranges from 20-3/4" to 26-1/4".
There is no way a fixed width hitch would work with all of them.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2025 John Deere 3025E (A64126)
2025 John Deere...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
3148 (A63117)
3148 (A63117)
Frontier Forks (A64126)
Frontier Forks...
2022 EZ-GO ELITE...
