Picked up my first welder today
   / Picked up my first welder today
Arc Weld, sounds like a good idea, right now I only have 6011 rods though. I like the idea of marking the plate and trying to weld within the parallels. The DASH acronym is good also. Hopefully Friday I can get a little time to play around. I brought home a pad of 1/4 plate from last nights class. Not pretty, but it gives me something to gauge improvement as I progress.
Ha! Exactly what I plan to do... I am about 10mi away (I think) from ShieldArc and hope to invade his domain next week! No kidding. :D
Good for you dragoneggs, have fun, post some pics.
   / Picked up my first welder today #53
You can do a pad with 6011. Pads are also good for practicing your stops and starts. Stop half way and try to get your restart to be unnoticeable. The best way is to strike your arc about a 1/2" ahead of where you want to start and then go back to fill the previous crater. The weld will go over where you struck the arc so it doesn't matter if the start was ugly. 6010/6011 are a little different from other rods (electrodes). Normally you use a slight back and forth whipping motion with them. They are a high penetration rod so what you are doing is digging into the steel and then going back to fill it up. Done right it will have the infamous stacked dimes look. Shield Arc has posted some pictures of 6010 beads.
   / Picked up my first welder today #54
Done right it will have the infamous stacked dimes look. .
Never did like that look. I like when a weld looks like you just ran your finger over it to smooth it out sort of like when you caulk something.
   / Picked up my first welder today #55
That's why 6010/6011 are different and pipe lining is almost like a different trade from other welding. 6010 will never be as smooth as other rods. If you want real smooth try 7024.
   / Picked up my first welder today #56
Shield Arc do you have an open guest room? How far from MA are you :D.
Happy my shop is always open to anybody wanting to learn:thumbsup:. Unfortunately I'm on the other side of the country from you:(. But let me make this perfectly clear! I' am nowhere near a master! I can think of at least 6 or 7 guys right here on this forum who are better at welding than I' am.:cool:
Shield Arc, I would jump on that opportunity! If I ever make it out there I'll take you up on that :thumbsup:
Today I picked up 80ft of #1 cable, new ground clamp and quick connects at the LWS. I made up a pair of 40ft leads. Until I get my garage plug wired I can plug the welder in the basement and run the leads out the bulkhead to the driveway.
   / Picked up my first welder today #59
"But let me make this perfectly clear! I' am nowhere near a master!"
The pictures of your welding and craftsmanship don't agree with your statement.:ashamed:
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
