CarryAll Project Just Completed
/ CarryAll Project Just Completed #1
bobm6996
Greenfield, Indiana
Mahindra 5010 4WD HST Cab, Mahindra 2615 Gear, Scag Tiger Cat 48", Gravely 42" ZTR, EZ GO Gas Golf Cart
Purchased the TSC CarryAll and created a platform for stuff and also to hold a 30 gal sprayer.
It is 4ft deep and 6ft wide with a 4ft high back. I placed 4x4s on the bottom and bolted them to the carryall and used 2x8s on the back and bolted them. I then used decking screws to fasten all of the decking and back boards. I created a platform to hold the 30 gal. sprayer and plan to strap it to the raised platform when in use. I added a 8ft length of line to allow me to have a on/off switch I can use while seated on the tractor and it just plugs into a short connector on the battery when ready to use.
Created a place to store chains, chain saws, gas, oil cans, etc. so they will not slide all over the place. And created a rack to allow me a way to stand up rakes, shovels, etc. Still have room to carry bulky items on the platform using ratchet straps attached to eye bolts on the carryall to keep it from falling off (have brush to move soon from fence row cleaning). Want to also incorporate a small tool box and maybe a couple more storage cubby holes.
/ CarryAll Project Just Completed #2
Nice job. I was thinking of doing something similar. Now that I have seen what you have done... it has gone up a few notches on my TODO list.
/ CarryAll Project Just Completed #4
Yup. What this guy said. I like this setup.
/ CarryAll Project Just Completed #5
Looks great! Remember AC2 will be very corrosive to those chains though. That's why you only use hot-dipped galv, stainless or triple-coated fasteners with pressure treated :)
/ CarryAll Project Just Completed #7
Very functional for you. What does it weigh? One would need the FEL or front ballast to use it on a smaller CUT wouldn't they? The welds/steel on the County Line would have to be good to hold the frame plus a load wouldn't they. Others have made these to hold mounds of fire wood, so I guess it works okay. Just wondering ??
Thanks for the comments. @oldballs I do not know how much weight I have added building the platform, my best guess might be 200 lbs. and the carryall probably weights approx. 150 lbs. The unit is rated at 1000 lbs. I do not plan to haul wood or much heavy material on it, my primary purpose is to use for the spraying and as a portal tool carrier based on the job I am doing. Hauling what I need for fence work, clearing projects, etc., my thinking is I can take it to the area I am working and if needed drop it on the ground so it does not interfere with the tractor work.
/ CarryAll Project Just Completed #9
I like it! I bought the same carryall in the Fall, and have a pile of good pressure treated 2x8s and 2x10s, so I was planning to build something very similar. I like how you put the 4x4s on the carryall legs...I wasn't thrilled with how the bolt spacing would work of I bolted the decking directly to the legs, so that would save me a bunch of time messing around with it.
/ CarryAll Project Just Completed #10
That sounds like another reason for a Quick Attach for the rear......."Yes".
/ CarryAll Project Just Completed #11
Good job. If you are like me you will find more uses for it all the time,
/ CarryAll Project Just Completed #12
Nice!!! And when you don't have the sprayer strapped onto the "shelf", it can double as a "seat" so you can haul your wife around on it lol!!
I do have a quick attach for the 3pt, have not tried yet to see if it matches up, some implements work and some don't.
I like the idea of providing the wife a place to ride, will see what see thinks. I was thinking she could stand on the back and spray while I drive, but thinking that won't happen unless it is me back there.
/ CarryAll Project Just Completed #14
And another vote here for the quick hitch. You could put everything you need on that and pick up or drop off whenever you wanted and with no hassle. Good looking platform and good job building it.
JOHN DEERE 5090 EL TRACTOR (A65057)
JOHN DEERE 5090 EL...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
CAT 740 Engine (A68134)
CAT 740 Engine...
2012 PETERBILT 337 FLATBED W/ LIFTGATE (A67714)
2012 PETERBILT 337...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2020 KENWORTH T880 (A67714)
2020 KENWORTH T880...
