Wheelbarrow Tires
/ Wheelbarrow Tires #1
Kubotafan
Gold Member
Nova Scotia, Canada
G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
I have a wheelbarrow and since new the tires keep loosing air. Is there a simple solution or should I just put tubes in them?
/ Wheelbarrow Tires #2
Either a tube or I have had good success with slime. You can get it most anywhere.
http://www.slime.com
/ Wheelbarrow Tires #3
It probably only goes flat on the bottom, so just put that on the top and you should be okay. :D
......or try a can of fix-a-flat. Why not?
But first, check that it's not leaking from the valve first (the ol' spit test). Or blow tire up , flip it over and put some soap water on the treads and around the bead. Leaking air will blow bubbles, and there's your problem. This is a good way to find if the tire picked up a nail, or is leaking around the rim, etc...
/ Wheelbarrow Tires #4
Tubes for me. Easier than finding and fixing the leak.
/ Wheelbarrow Tires #5
Put Slime in it. You'll never have to worry about it again.
/ Wheelbarrow Tires #6
A tubeless wheelbarrow tyre? Are you sure ? Never seen one of those myself, although I haven't bought a new wheelbarrow for years. Everything I have with small/narrowl wheels has tubes.
That said, I wouldn't waste time with slime in a small wheel. Put in a tube.
/ Wheelbarrow Tires #7
buy a solid tire -- no air needed -- TSC sells 'em.
/ Wheelbarrow Tires #9
That's what I did, and have never regretted it. Got tired of fixing flats here where Locust and Osage Orange make a lot of thorns. The solid tire doesn't not ride as nice as the air filled tire in my estimation. But now that I have a FEL, the wheelbarrow isn't used that much...thank goodness.
/ Wheelbarrow Tires #13
My old wheelbarrow is over 20 years old and the original tire would never stay aired up. I finally bought a new tire and rim at Lowes for I think about $12 but that was over 5 years ago. I haven't used it much since then, mostly it just leans against the wall of my shop, but the tire is still aired up and I haven't put any air in it since I got it.
/ Wheelbarrow Tires #14
---------- But now that I have a FEL, ------------
That is a motorized wheelbarrow!
This is my motorized wheelbarrow!
On the forks. :D
/ Wheelbarrow Tires #15
My wheelbarrow came with a tube in the tire, but it still didn't like holding air. I put some liquid laundry starch in it. Liquid laundry starch does the same thing as slime, but costs about $2 a quart. Works great, I put it in the tires on my riding mower too.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2022 EZ-GO ELITE...
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
