U.S. States Most And Least Likely To Survive The Zombie Apocalypse
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse
It's well known that all the quitters and those that can't hack it move south. :laughing:
I have an alternative hypothesis, but I will refrain from articulating that hypothesis in the interest of maintaining civility.;)
Steve
You surely have days when you wonder how the economy will change due to The Zombie Apocalypse. Invariably, you come back to the same old realization: "I need the advice of an economist. An economist would know how to answer my question."
Steve
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #13
Steve
Hmfppft! I can only surmise you refer to those shallow souls who depart a veritable Eden to pathetically pander to the emptiness of material wealth in some misbegotten cubicle Hades. :laughing:
So, are your azaleas blooming yet?:)
Steve
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #15
Steve
Azaleas would not thrive in a cubicle, and the other inmates would likely sniff and piffle about their allergies.
How was your snowmobile season?
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #16
The red areas tend to be obese and can't run as fast or as far.
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #17
Some of the red areas would have trouble distinguishing targets. That would lead to friendly fire casualties which will definitely lower the survival rate.
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #18
" A Southern Boy Can Survive " Hank Jr.
Send them down South. We will F---- Them Up.
Send left overs back up North where they belong.
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #19
Yep. They're only hope is to trap the zombies in pits filled with week-old sausage gravy, then throw biscuits at them. I think a biscuit can be thrown overhand without getting up from the table, should work. :)
   / U.S. States Most And Least Likely To Survive The Zombie Apocalypse #20
Someone should take that map over to the politics thread, then overlay the last 3 presidential election maps that show county-by-county red-blue results. You'd by quite amazed by what results...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2012 MACK GU713 (A58214)
2012 MACK GU713...
