T4.75 PTO issue
   / T4.75 PTO issue #1
Longmeadow Farm
Fonda, NY
John Deere, Agco-Allis, Allis Chalmers
I recently purchased a T4.75 with a 504/540E PTO option and 12/12 power reverser transmission. It appears that to shift from 540 to 540E and visa versa..you need the engine off. grinds gears otherwise. I do have the PTO engagement lever in the off position and checked the PTO rotation.. all is normal. I have tried all combinations of actions.. clutch in, power reverser in neutral, transmission in neutral,, et al .. no luck. The only way you can shift the PTO is with the engine not running. I asked the dealer for some feedback..but the New Holland dealer hasn't gotten back to me in a couple of days... any suggestions??? or is this normal for a 540/540E power reverser tractor???
   / T4.75 PTO issue
How does the operator's manual instruct you to shift the PTO?
The operators manual doesn't say much of anything except ...push the PTO speed selector lever forward for 540E and pull the lever back for 540.. nothing more
   / T4.75 PTO issue #4
Then I guess if my dealer hadn't gotten back to me about that in " a couple days" I'd be after him. Until then, shut off the tractor before shifting the PTO. If the shifting mechanism is between the engine and PTO clutch, that's the way you will have to do it anyway. If the mechanism is between the clutch & output shaft, you may get better info that lets you shift while the tractor is running.
   / T4.75 PTO issue #5
I would be on the phone and ask the service manager directly how it is suppose to operate.
   / T4.75 PTO issue #6
Agreed. If the OP is one of those guys who repeatedly calls the sales department for service issues after the sale, that needs to change immediately.
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2004 John Deere 120C Excavator (A59213)
2004 John Deere...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2017 Takeuchi TL12V2 Skid Steer (A59213)
2017 Takeuchi...
2022 Chevrolet Express (A57148)
2022 Chevrolet...
