Case 530 Front Spindle
   / Case 530 Front Spindle #1
BEL169
Washington CH, OH
John Deere 670 Compact
Hi , looking for help with a Case 530 utility with a HD front axle. Right spindle is loose and in need of repair.
Need to know how to disassemble and remove pin and bushing. Pin moves approx 1/2" . Also need recommendations on repair, i understand that there are very few parts available for the HD clevis type axle See photos attached
   / Case 530 Front Spindle #2
I can't comment on parts availability but to say that I would check with Roberts Equipment (in Ohio) West Kentucky Tractor Parts, and Wengers (in Pennsylvania). They have a lot of used parts and parts tractors, so you can probably find a used spindle in good shape. That said, a good machine shop that does smaller jobs can weld up and turn down a spindle and do amazing repairs. I have had several repaired this way, and it was about $150 each time (2 hours of shop time) and the repairs were flawless.
On getting your pins pressed out, a hydraulic press is typically used, either a portable one or remove the entire front axle and take it to a stationary press.
Good luck!
Hi Thomas, Thanks for the quick reply
I'll check out the parts sources and let you know when i get the spindle disassembled.
BEL169
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
1043 (A50459)
1043 (A50459)
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
