New Holland TN65 wont cut off with key
   / New Holland TN65 wont cut off with key #1
clashin
Tn
NH TN65
Hello! New member here, just have a question about a boggling mystery my dad has had with his early 2000's NH TN65 tractor not.cuting off with the key.
This has been going on for a couple of years. He changed the switch, because the battery kept getting drained overnight. That fixed the dead battery issue, but it didnt do anything for the not cutting off. He has to clutch it to kill it now.
NOBODY local has anything else to try except bring it in, or sell it. He is about to that point. Hes been annoyed anyways since he bought it brand new, and the paint flew off the hood within a few years due to bad primer (just like my 2008 ford crown vic did).
This seems simple, but everyone says "it wont CUT OFF, or START?" And we say wont cut off and it puzzles them.
Just a last ditch resort, theres an estate sale this weekend and it may go the highest bidder "as is", and we will cut our losses there if this is gonna end up costing us another thousand dollars or so to figure out.
Thanks in advance for any help.
   / New Holland TN65 wont cut off with key #2
The fuel shutoff solenoid may be sticking open even when power to it is shut off with the key switch. Check the solenoid terminal with a test lamp when the key is off and the tractor running; if no light, replace the solenoid. If power is present, look for a pinched wiring harness behind the cylinder head/engine block.
Thanks for the quick reply, I relayed the info and he wanted me to ask where the cut-off solenoid is, if you dont mind. He has a manual, but it lacks the electrical systems.
Thanks again!
   / New Holland TN65 wont cut off with key #4
Screwed into the top rear of the injection pump. It has an electrical connection using a single wire.
Thanks so much, ill come back and update the thread after we get it figured out!
1993 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
1993 Ford F-250...
2014 Volvo L60G Articulated Wheel Loader (A56857)
2014 Volvo L60G...
2000 TCM Pro-G 25 5,000lb. Straight Mast Propane Forklift (A55973)
2000 TCM Pro-G 25...
2007 STERLING LT9500 MIXER TRUCK (A58214)
2007 STERLING...
SHOPBUILT 76" X 9' S/A TRAILER (A52708)
SHOPBUILT 76" X 9'...
GRAIN BIN - APPROX. 14' ACROSS (A52708)
GRAIN BIN -...
